Lotsa fuel on ground when starting
7 replies to this topic
  • Paewraul
Posted May 08, 2006 - 09:36 AM
whenever I start my 01 Wr 426 I get a puddle of gas that flows out of the "breather tubes" that run out of the carbs. &%$#@!? Any ideas? This bike has been way harder to kick this year for some reason as well.
  • dbailey223
Posted May 08, 2006 - 10:37 AM
Carb float sticking?
  • Paewraul
Posted May 08, 2006 - 10:39 AM
Good idea, someone else told me to clean the bowl today.
  • byggd
Sounds like it's time to pull the carb, take a look-see and give it a once over. Sounds like you have have some dirt in the needle and seat. Does it start to leak as soon as you turn the gas on?
  • Paewraul
Posted May 09, 2006 - 06:09 AM
nope, just leaks when I kick it. My bike seems to need a little goose of the throttle to get it to come to life when trying to start.
  • byggd
Posted May 09, 2006 - 11:36 AM
Hmmmmmm....maybe one of the intake valves is too tight and some of the compression is blowing back into the carb :crazy: It's a long shot but it would explain both of your problems.
  • RichBaker
Posted May 09, 2006 - 02:59 PM
Sounds like the float is set too high...I'd lower it a little.
  • Paewraul
Posted May 09, 2006 - 07:18 PM
I'll try cleaning it and adjusting the float tomorrow. How you guys are standing by. Carbs are my nemisis!
