2005 wr throttle stop
6 replies to this topic
  • poison-dwarf
Posted May 06, 2006 - 04:26 PM
do i need to do the mod or not, all info on here that i can find that is points to 250/400/426. if so any pictures and lenghts etc. would be ace!
sorry if i am asking old and boring stuff!! :crazy:
i have done the airbox and AIS. exhaust and grey wire, thanks to this site, and yes it did make a massive difference, the main ones being the grey wire and exhaust.
thanks
lloyd
  • Cairn
Posted May 06, 2006 - 08:23 PM
P-D:
The most straightforward solution is to purchase and install the 2005 YZ450 throttle stop. Part number is 5NL-14591-00-00 according to a previous post.
Cairn
  • odonnks
Posted May 07, 2006 - 04:30 AM
Check out this thread, its has the proper lengths.
http://www.thumperta...t=throttle stop
  • poison-dwarf
Posted May 07, 2006 - 01:34 PM
thanks guys, i will check which one i have got and go from there, i will order the YZ part anyway.
before i start is it easy to find, as i said earlier all i can find are links for 250, 400's and 426's. is it in the same place under the metal cover as in i have to remove it and i will find it?
i know, i know, you have all done it, its easy! but so is rocket science to a rocket scientist!!
  • odonnks
Posted May 07, 2006 - 02:43 PM
You don't need to remove amy covers to get to the t-stop screw.
Look at the bottom of the section that the cable is routed to . I found access was easier from the left side from in front of the rear tire.
  • poison-dwarf
Posted May 08, 2006 - 12:38 AM
ok on the case tonight!!! :crazy:
ace just done it! found the screw which was fitted was already cut! it must have been done by the dealer. it measures 22m total length. i suppose it is fully open then!
  • sidewinder2
Posted May 10, 2006 - 02:00 PM
The YZ throttle stop is 23.5 mm, 22mm may be a little short! :crazy:
