XRL Battery
6 replies to this topic
  • YUKI
Posted May 06, 2006 - 06:34 AM
Good morning,
Is there a replacement battery for the XRL that weighs less than what Honda supplies the bike with?
ThanX, Yuki
  • roadcam
Posted May 06, 2006 - 09:05 AM
if there is, I've never seen it ... what little weight you'd save, could probably be duplicated by skipping lunch ... :crazy:
  • Dual_Dog
Posted May 06, 2006 - 09:43 AM
I took a chance on installing an aftermarket (not Yuasa) battery sized for the DRZ400E. Mine was dead anyway & I figured I'd take it back if it didn't work. It's a Power Source brand, PN WP7B-4.
It fits inside the XRL battery box *almost* without any fitment issues. *I did have to cut off about 1/16" off of the + cable tang, really easy, & I used one piece of foam packing from the box to take up the gap behind it due the smaller-sized battery case.* :ride: Works great & it fires up easliy. :crazy:
It's smaller in size & weighs about 1.5 lbs. less than OEM. Probably has fewer cold cranking amps that the larger XRL juice box, but that wasn't a concern for me since it doesn't get that cold out here in sunny So Cal. :ride:
  • GIANTac1
Posted May 06, 2006 - 01:29 PM
Has anybody successfully relocated the battery from their XRL under the seat or somewhere else? :crazy:
  • TREADMARKS
Posted May 06, 2006 - 06:26 PM
I put a 250 battery in my air box, along with all the electricals.
It had more cranking amps, with a little less reserve.
  • rmhrc630
Posted May 06, 2006 - 07:13 PM
AS you may know I am fitting the estart from the XR650L to my XR600.
It's a long laborious project.
As the XR600 does not have a battery location I needed to fin out how to fit a battery and where would it go.
Soem people relcoate to the airbox which killds airflow and is quite frankly not an option for me.
This is what I did:
1. Bought an OEM CRF450X battery - awesome battery which big CCA.
2. Am having a small alloy battery tray made.
3. Will locate the battery right next to the carb - lying down and with the support of the starter motor. The battery will be on an angle and be in line with the frame.
4. This makes sure the wires to the starter motor are as short as possible and ths most punch is delivered to the starter. It also locates the battery centrally and this I assume will assist handling especially for you XR650L riders.
I'll post some pics when I get it all done. You really should check out the CRF450X battery - it's very small, much lighter and fingers crossed will pack and repack a punch to start the big 650L.
Cheers
  • GIANTac1
Posted May 06, 2006 - 08:20 PM
This is what I did:
Cheers
I am looking forward to seeing pictures :ride: Thanks for the idea and reply :crazy:
  • 3 replies
  • Hot  29 replies
  • 17 replies
Washington
  • Hot  32 replies
  • 9 replies
