XR600R Stock/modified? What should you do?
6 replies to this topic
  • philipstjohn
Posted May 05, 2006 - 08:31 PM
I have a clean 2000 XR600R, completely stock minus the exhaust. Should I do anythiing more if the power is enough for me?
  • TwistiT
Posted May 05, 2006 - 08:42 PM
if everything feels right to you, then why bother? Maybe set the suspension up for your weight.
  • raven-9
Posted May 06, 2006 - 12:15 AM
i had a 94 model with the following:
flat slide 42mm mukiuni cab
630 bore kit
cr 500 suspension and upside down fork legs/
cr 500 fork triple tree's
oversized disk
full exaust and header pipe
KTM gaurds
and alot of other little bits and peices
you can go mad ,b but if your happy with the bike how it is now, save the bucks for an update down the track some time, the XR's are never going to compete in the handling and weight stakes with the newer 4 strokers, mine had plenty f power but it just didn't have that wind on wheelie value of the KTM im now on
i bopught the XR set up already of a guy pretty cheaply, so i rode it for 12months to save up for the bike i know own:)
if you have to do a mod, i would recomend it to be a suspension mod, the cr 500 shocks wrere a good thing, but im sure there would be a cheaper suspension mod to do..maybe a new can or deristrict the originl pipe to
here's a piccy of the old girl, i sold it to a freind so i still get to ride it every now and then
http://i14.photobuck...myxr600_002.jpg
  • cleonard
Posted May 06, 2006 - 07:03 AM
The choke plate is a weak link. It has a steel flapper that can break off and get sucked into the engine. On my XR600 it was about to break, and the entire choke plate had a big crack in it. There are aftermarket replacement plates available. I just took my choke out completely. Some issues on real cold days, but I have a procedure for that now. Tip bike over until it "floods" then start.
Remove the intake snorkle, if it is still there. If it has not been rejetted, a larger pilot can make for easier starting. A larger main will help for top end power.
Handguards can be a wonderful addition.
Suspension upgrades. Springs that match your weight, unless you weigh the 170 pounds the stockers are made for.
  • xr500_89
Posted May 06, 2006 - 09:07 AM
well im 6' 1" and weigh 170-180 that would mean the stock suspension is perfect for me?
  • roadcam
Posted May 06, 2006 - 09:14 AM
properly jetting the carb is a very good mod ... the bikes come drastically lean from the factory ... re-jetting not only increases performance, but will result in a much cooler-running engine, ... :crazy:
  • cleonard
Posted May 06, 2006 - 10:37 AM
Perfect, um I doubt it. At least it's in the ball park. XR600's are known to be well under sprung. It's not suspended for a MX track. I'm around 260 and the stock springs are not even close to what I need for trail riding. It really all depends on rider preference. If you are an aggressive rider you might benefit from stiffer springs , even though you weigh about what Honda designed the suspension for. It also depends on what kind of riding conditions you experience.
  • Hot  186 replies
  • Hot  60 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
