2001 clutch in a 2000...426 ?
14 replies to this topic
  • fire426
Posted May 04, 2006 - 07:56 PM
Need some help.....will a complete clutch, including the basket and inner hub from a 01 426 fit into a 2000 426. if so are there any other parts that would need to replaced i.e. short/long push rod assembly, thrust washer...etc.
  • cowboyona426
Posted May 04, 2006 - 08:11 PM
I think the 01 has a different gear on the basket, so it may not work on the 00. If you want an 01 spec clutch, all you need is a few parts, see my thread on "Clutch fix for 00 YZ 426F" or something to that effect for more info.
  • cowboyona426
Posted May 04, 2006 - 08:12 PM
BTW, welcome to TT! I see you are from WA, what part?
  • fire426
Posted May 04, 2006 - 08:21 PM
Spokane
  • cowboyona426
Posted May 04, 2006 - 08:26 PM
Did you just buy your bike? You may have my old 426...
  • 426_Texan
Posted May 04, 2006 - 08:27 PM
I wish they would sticky that to the top. After the 450 cam mod, that is the next best thing! :crazy:
  • fire426
Posted May 04, 2006 - 08:44 PM
It's not my bike it's a friends. I have a 01 ..... He got it from a guy in Portland.
another ? would the clutch pack from the 01 fit in the 2000 basket?
  • Terrain Rider 4z
Posted May 04, 2006 - 08:52 PM
Hey is this Rob??
Ryan
  • fire426
Posted May 04, 2006 - 08:54 PM
yes, I'm trying to get some info for John.
  • fire426
Posted May 04, 2006 - 09:00 PM
Hey is this Rob??
Ryan
Ryan, If you run across any info on this let me know.
  • 426_Texan
Posted May 04, 2006 - 11:21 PM
The '01 setup has a boss spring in place of one of the disks in the '00 setup. The pushrod setup is also different.
Here the list of parts need to convert the '00 setup to the far superior '01 setup
parts list for the 2000 --> 2001 clutch mod
5JG-16321-00-00 PLATE, FRICTION
5JG-16383-00-00 SPRING, CLUTCH BOSS
5JG-16384-00-00 PLATE, SEAT
93511-32027-00 BEARING, BALL (PUSH ROD ASSY.)
5BE-16356-00-00 ROD, PUSH 1
5JG-16357-10-00 ROD, PUSH 2
5JG-15453-00-00 GASKET, CLUTCH COVER
You can go to www.yamahaoftroy.com and use their parts finder if you want an exploded view to actually see the differences between the two setups.
Posted May 05, 2006 - 08:37 AM
Go to:
http://www.yamaha-mo...parts/home.aspx
Click "proceed to parts catalog". Put in "motorcycles", "2001", and "YZ426FN", then go to the clutch page. You need all of items 7, 8, 12, 13, 14, 17, 21 and 22. Items 7 and 8 are the basic clutch plates, and if yours are OK, and you have the right number of each, you can most likely reuse them. However, if you are planning to replace the basket, you should use at least new friction plates (#8). The basket ASSEMBLY from Yamaha has a revised part number, but I don't know what the difference is, exactly. However, the Hinson basket, which utilizes the OEM gear and cushion, is the same for all 3 years.
  • cowboyona426
Posted May 05, 2006 - 11:16 AM
Yes, an 01 pack will fit in an 01 clutch.
  • cowboyona426
Posted May 05, 2006 - 11:17 AM
It used to be there, but someone decided it wasn't deserving of a sticky apparently.
  • fire426
Posted May 05, 2006 - 01:07 PM
thanx for all of the help.....everyone. I'm new to thumper talk and to getting a big 4-stroke. you guys have been great ......thanx again.
  • 0 replies
  • 0 reviews
  • Hot  33 replies
  • 5 replies
