crankcase oil seal 03 yz450
4 replies to this topic
  • 3rdcoast
Posted May 04, 2006 - 07:39 PM
(search function not working)
trying to replace crankcase oil seal (just inside sprocket), how do I get the old one off and replace with the new one? I took the two bolts off the first cover. Is there an easy way to POP it out of there?
03 yz450f
thanks,
Erik
  • tmckeown
Posted May 05, 2006 - 01:37 AM
Hi,
This is usually done when you have splitted cases already.
There is a collar you have to pull out and then bent an ods screwdriver or something so that the tip is in a 90 degree angle. Then just yank it off.
Timo Mc
  • MotoGoalie
Posted May 05, 2006 - 07:44 AM
03 yz450f
thanks,
Erik
Don't listen to that dude.
You don't have to split the cases.
Get a small screwdriver and PRY it out. It's pretty easy, just be careful and don't scratch up the shaft or the case.
Be sure and clean the area up really thoroughly.
  • mkporn
Posted May 05, 2006 - 10:01 AM
Easier yet. Screw a drywall screw into the seal and remove with pliers.
Or you can do as suggested and drive a screw driver into it and pry it out.
It is easier if you remove the collar that is separate form the shaft first. Make sure the o-ring under the collar is in good shape.
  • chrisn6104
Posted May 05, 2006 - 10:26 AM
Pry it out as MotoGoalie said. I just replaced my seal there about 2 weeks ago. Used a small screw driver and worked the seal out. You can easily get it out without damaging the case.
  • Hot  30 replies
  • Hot  38 replies
  • Hot  47 replies
  • 3 replies
  • 10 replies
