chain length and how to cut a chain?
1 reply to this topic
  • wr400rider
Posted May 04, 2006 - 02:45 PM
i am changing my chain and front sproket the chain i bought has 120 links but the chain i have on it now has only 114 links? what size of rear sproket would i have on there for it to make it 114 links in my chain? the sproket is aftermarket not stock. and how do i cut the chain properly and fasten the chain togethor right?
  • simon@vic
Posted May 04, 2006 - 04:24 PM
cutting a chain is easy
-grind down the heads of the rivets on the link you want to cut
-flip the chain 90 degrees
-use a big, wide angle chisel to knock off the face plate
installing the master link is easy too
-slide the link in
-use big vise grips and a 8mm nut to press the face plate on
-clip on the clip
buy a DID or EX, o-ring or x-ring chain!!!
avoid umi chains!!!!
