Need Jetting Help
7 replies to this topic
  • bandit99
Posted May 04, 2006 - 07:34 AM
2005 WR450. 168 main, 48 pilot, JD red #5, WB E2 pipe, snorkle removed, Boysen Qucik Shot, fuel screw 1 1/2 turns. Alt 500 ft.
The quickshot really helped with the initial surge when I hit the trottle. The problem I am having is there is a lag after the initial surge and when the power comes on. Is this a needle adjustment? I think it is wanting more gas but I am not sure. Any thoughts???
  • Bandit9
Posted May 04, 2006 - 07:46 PM
Do you adjust your fuel screw after the bike is warmed up? If not, then try that first b/c it is easy. 1.5 turns out, is that a starting point. Depending on the weather/altitude, the ideal setting for that day might be a little more or less than 1.5. There is no "magic" number. If that doesn't clear it up, then drop the clip one more slot to give some more fuel.
  • pkcof
Posted May 04, 2006 - 10:04 PM
ok, where is the problem exactly ? ... 1/4 throttle, 1/2 or WOT cause it sure sounds like a needle choice or clip position to me. I use what they call the Yamaha racing needle in my '05. It came with the bike when i bought it new from the dealer here in Melbourne, Australia. If you can get your hands on one and try the 3rd or 4th clip position i think it may just solve your problem. Possibly a #170 main may also help due to the fact that you've opened up the breathing from the airbox to the pipe ....
  • bg10459
Posted May 05, 2006 - 06:50 AM
This leads me to believe it is the needle. Try the blue #3 and see what happens. What are the temps there?
  • bandit99
Posted May 05, 2006 - 02:52 PM
Temp was in the low 70's. I am going to try a 170 main just because that is really easy to do. I recently put the Boysen Quickshot on and I adjusted the pumpt to the .10 mm setting (or is it .01). Maybe I need to open that up and give it more squirt? I have the blue needle and will mess with that too. I am going to do a test and tune day tomorrow and I'll let you know.
  • pkcof
Posted May 08, 2006 - 09:34 PM
sorry i forgot to ask ... have you done the grey wire mod yet ?
  • odonnks
Posted May 09, 2006 - 02:06 AM
You might try to reduce the leak jet size.
The LJ helps determine the AP squirt volume. I never had this problem but if the QS helped and lag comes after the AP squirt (which is what it sounds like) Try a smaller LJ.
I run a #35 with the QS.
  • OneToGo
Posted May 09, 2006 - 10:10 PM
Agreed, you guys in OZ`are heading into winter...I would go with the MJ170 and get a 40 and 35 Leak. I ran Blue clip 3 and MJ 170 in temps less than 20c and the bike was great- similar setup to yours...
The 06 WR is fairly sensitive to jetting changes (and fussy IMO). Try doing the airbox cutouts, helps a little as well :crazy:
A`YZ AP diaphram may also be worth a look for a longer squirt. :ride:
