2001 Yz 426 Starting Technique
33 replies to this topic
  • CGAYER
Posted May 03, 2006 - 10:44 AM
I Was Just Given A Yz 426, Can Figure Out How To Get It Started.....can Anyone Help?
  • 2fastwhitey
Posted May 03, 2006 - 10:56 AM
Turn the gas on, kick the bike through with the compression release pulled 2-3 times. Let the kick return to the top and without the compression release pulled find TDC(the hard spot). Pull the compression release and push it one click past TDC(meaning down past the hard spot but only a little). Then let the kick start return to the top of its stroke and kick it HARD all the way down to the foot peg.
Don't play with the gas or anything while your trying to start it. Keep your hand on the master cylinder of the brake if your not sure you can kick it without twisting the throttle. If you already did, you'll need to pull the plug and replace it or wait till tomorrow.
  • Zique
Posted May 03, 2006 - 12:20 PM
Starting Procedure
This doesn't mention it, but if it has been a few days since you last started your bike, you can give one quick "blip" of the throttle (I said just a blip!) before going through the routine.
  • MisterMan
Posted May 03, 2006 - 09:09 PM
its amazing. i ride with a buddy with the EXACT SAME BIKE AS ME!!... (426...02') only diff is i have a pipe on mine. both bikes valves r in spec...(as r jetting) yet his is a 5th kicker.....mines a 1-2nd. 20 if flooded. hah
  • jbrooks26
Posted May 03, 2006 - 10:26 PM
I wish someone would "Just Given Me" a bike. LOL, Great find if it was actually given to you.
  • MBrider426
Posted November 01, 2006 - 11:10 AM
i have found on my 02 yz426 that if it doesn't start within 3-4 kick to play with using hot start or choke. just try to find out what the bike wants.
  • slidenride
Posted November 01, 2006 - 11:18 AM
yeah, i have an 02 and just pull the choke out,with no throttle,and kick it, obviously find compression stroke first and take it just past with decomp lever in
  • Type Gendy
Posted January 30, 2007 - 07:43 PM
i BOUGHT an 01 426 2 weeks ago and have only gotten it started twice since then. I have been reading on here for days about all the different starting techniques and she still wont fire. I'm guessing the plug is fouled by now? Do you really have to take the gas tank off to change a plug? :crook:
  • jbrooks26
Posted January 30, 2007 - 08:13 PM
Yes, but it isn't really a big deal. Take the two seat bolts out and remove the seat, remove the rubber retaining strap at the rear of the tank, remove the two tank mount bolts and remove the two screws at the bottom of the rad shrouds, it will lift right off. OH, don't forget to turn the fuel off and disconnect the fuel line. After you have done it a few times it will be second nature. On the up side, you don't have to get to the plug very often. Hope this helps.
Josh
PS. The starting procedure is pretty simple. Cold engine: Choke on, push kicker to the hard spot(compression stroke), pull the decomp lever and push the kicker down about 1 inch, release the decomp, let the kicker back to the top and kick through. This too will become second nature before you know it. These bikes need a good steady kick, not the short strokes like you would use on a two stroke.
Josh
  • Smokeslider
Posted January 30, 2007 - 08:15 PM
Don't give up on the starting procedure, I threw quite a few tools across my garage when I was learning how to kick my 98 YZ400, but once I figured out how the bike wanted to start, it was easy.
  • Drav
Posted January 30, 2007 - 10:00 PM
Yeah dont give up, the first two days I got my 02 I think I added another 3 lbs of muscle onto my right thight...and bruised the living hell out of my foot....
After learning how to do it properly she starts in 1 kick every time if shes warm, 3 or so if shes cold.
  • Kyle Prior
Posted January 31, 2007 - 02:34 PM
I wasnt able to get my bike started for the first week or two after I got it. Maybe a good thing, since I would have wanted to ride it, and didnt really know how yet. I dont even find the hardspot, I just got about 2 inches down without finding it, and then give it a good hard kick. It usually works very well, and the bike starts 1st-2nd kick every time.
  • Goosedog
Posted January 31, 2007 - 03:27 PM
I love this line in the starting proceedure that Zique posted.
"Enemy tip: If you don't own a YZ-F but want to ruin the day of a YZ-F rider who you don't particularly like, go over to his unstarted YZ and give the throttle four or five healthy twists. The accelerator pump will fill the engine with fuel and it won't start until the following Thursday."
  • GCannon
Posted January 31, 2007 - 03:40 PM
If someone "gave" you this bike, I will bet it has been in storage for a while.
Remove and clean the carb and make sure all passages and jets are clear.
Then do the starting drill. I bet it starts a lot easier.
  • Type Gendy
Posted February 01, 2007 - 05:22 AM
So could it be the extreme cold weather causing this not to start, or u think ih ave a fouled plug on my hand?
  • Goosedog
Posted February 01, 2007 - 05:24 AM
Changing the plug would have been the first thing I tried anyway. Cheap and easy to do.
  • Zique
Posted February 02, 2007 - 02:45 PM
+1:thumbsup:
+1:thumbsup:
All good advice. If you just recently aquired the bike, whether in storage or not, it's always a good thing to change out and clean everything you can. Fresh fluids, lubes, plug, etc.
  • yamarider628
Posted February 04, 2007 - 06:48 PM
The only way mine would fire is this way
1) Tell it you lucky for owning such a fine machine.
2) Turn on Gas, and choke if needed( dont think about touching that throttle)
3) Stretch while sitting
4) Before it knows your going to try to start it pull kickstart out as fast as possible find TDC and kick the hell out of it.
5) If she dont start turn off gas lay it on its side cause its probably already flooded. (Kicking dirt in its face is exceptable if you promise to clean it shortly after the day of riding)
6) Start over from the top!
Have fun the bike is a great one and just takes some gettin used to!:ride:
  • buzzgrizz
Posted February 04, 2007 - 07:01 PM
YES!
:ride:
  • buzzgrizz
Posted February 04, 2007 - 07:03 PM
Best to wear boots when cranking because it will eat a hole in the bottom of any other shoe.
  • On January 15, 2017
  • Hot  50 replies
