'06 12 tooth sprocket fit?
12 replies to this topic
  • xcape
Posted May 02, 2006 - 05:21 PM
Anyone run a 12 tooth front? does it fit right? Is there abnormal wear on swingarm guard?
I rode tight trails last weekend for the first time and the gearing is crazy tall. My buddies bike was in second gear and I was having to pull in the clutch in first so as not to run into him.
I DON'T WANT HAVE A RECLUSE DISCUSSION :crazy:
I dont have the cash nor do I mind operating a clutch thanx.
I was thinking of 12 / 51 ? Then run a 13 (stock) on the track.
  • motobark
Posted May 02, 2006 - 07:25 PM
Sounds like you need to pass your buddy so you can ride faster. :crazy:
Seriously, I wouldn't use a 12, the 13 is hard enough on the front chain slider. I ran a 15 on my '03 and I'm planning on going to a 14 on my '06. The smaller cs sprockets are not only harder on the slider, they're harder on the chain and sprocket itself too.
A thought on the clutch issue, don't be afraid to use it. I've seen some comments on here about not using the clutch, I don't agree with the only using the clutch for starting and stopping theory. The clutch is a powerful tool, I think a lot of riders don't use it enough. Even on a 4 stroke. I use mine constantly, and I don't mean abuse either, my clutches usually last at least 2 years. I use it to come out of turns faster, go into turns faster, and a quick jab before jumping will help you jump further if you have to clear something. (That's actually why I personally don't like Recluse clutches.)
Sorry, the clutch comments weren't meant for you directly, more of a general comment to the TT community. I didn't mean you specifically didn't use the clutch enough, your comment about using it just made me think about what others had said on the subject.
Hey, did I just hijack a thread?:ride:
  • xcape
Posted May 02, 2006 - 07:33 PM
Yep, doing allot of clutch work up tight/steep climbs. But would be nice on the twisty low speed stuff not to have to coast all the time. Couldn't pass my buddy if I wanted to way better rider than me on the trails.
Guess I'll be changing the rear sprocket then I'll order a 52 for the trail and switch back to stock for the track.
What is the biggest rear you can run?
  • kxman
Posted May 03, 2006 - 03:44 AM
I am running a 12 on my 06. It helps a lot in the tight stuff
  • xcape
Posted May 03, 2006 - 04:08 AM
have you noticed any unusual wear? how long have you used a 12 toooth?
  • kxman
Posted May 03, 2006 - 05:01 AM
Not yet but i only have 5 hours on it.
  • jgerdi
Posted May 03, 2006 - 01:08 PM
I just ran a hare scramble here in Florida. Bumped up to 'A' class to Gage my new found speed on my 06 LE. I went with a 12 tooth . the difference is when my buddies, experienced A riders ,were stalling there 450's because the gearing was too tall for the tight stuff, I was cutting through the trees like mad. I did loose Little top end but 95% of the ride is 1st 2nd almost never 3rd gear.
I will be switching back to the 13 tooth for tomorrows motocross ride at countyline in panama city. 100' table ,long straights, clay with a little sand...I'm gettin a chubby already. I am going to leave the 110' double table alone.
  • black_n_blue_thumper
Posted May 03, 2006 - 09:11 PM
I have a 12-52 on my 06. I love it. She is a woods weapon, too bad I am not. :ride: Slider wear is increased but so is my fun factor so I really dont care. :crazy: Sliders are replaceable. I had the 12T on my WR for almost a year with no problems either.
  • One Louder
Posted May 03, 2006 - 09:19 PM
what's easier on the motor: a small front sprocket or a big rear sprocket? :crazy:
  • 00YZ426FMRCD
Posted May 04, 2006 - 05:18 PM
Ditto....
  • kxman
Posted May 04, 2006 - 08:48 PM
If it wears out the slider I will just buy another. Not a big deal.
  • 00YZ426FMRCD
Posted May 05, 2006 - 09:33 AM
Aside from eating your chain slider - A front sprocket with fewer teeth works the chain harder and will rob power - The chain has to curl more to match the smaller diameter. Also harder/more torque on your countershaft - Possibly resulting in a ruined seal or at extreme, a bent countershaft.
I would maybe goto a 13 tooth and/or add more teeth in the rear - No way I would ever run a 12 tooth...especailly on a new 06.
Just my .02
  • kxman
Posted May 05, 2006 - 09:40 AM
Just my .02
This ever been proven on a dyno? All I know is my bike works much better for me with a 12 tooth. My bike, I set it up the way I like it.
