only starts with hot-start lever
9 replies to this topic
  • specialk6r
Posted May 02, 2006 - 10:44 AM
Well I was playing with my carb and checking the valves yesterday, and after I put everything back together it only starts with the hot-start lever pulled. After it starts, if I let go of the lever it idles low and soon stalls. If I pull the lever again it idles up high like it normally would if the choke was pulled. Any suggestions?
  • clark4131
Posted May 02, 2006 - 11:01 AM
Did you pull the slide out of the carb? If so, check the orientation of the plate as you may have it in upside down. If not, check your idle setting, jets and carb boots...SC
  • MountainMax
Posted May 02, 2006 - 05:14 PM
What exactly does this hot start device do? it may help in the diagnosis?
  • Numskull
Posted May 02, 2006 - 05:42 PM
The hot start is opposite of a choke. Your choke richens your mixture, where as the hot start leans the mixture.
Its kind of really hard to say, cause my bike is really lean to begin with, so if I pull my hot start at idle it will die from starvation. But yours might be richer and you just need to adjust your idle. You ever hear a lawn mower die just as its running out of gas? It will actually increase in rpms for a sec or two because of the lean mixture. Well its just a thought, or you put it back together wrong :crazy:
  • specialk6r
Posted May 02, 2006 - 06:23 PM
It's actually set up pretty lean, with stock jetting, aside from the #70 starter jet I put in, and I dropped the clip one spot from the 4th to 5th notch on the needle, (the rest of my rich jets were backordered.) I'm stumped, would tightening the fuel screw be a good first step?
  • Numskull
Posted May 02, 2006 - 06:35 PM
Well it should be in your pilot circuit. Its either getting to much fuel or not enough air.
  • Baron Von Beard
Posted May 02, 2006 - 06:45 PM
It sounds like you are set too rich on the pilot circuit. When you have it running, turn the fuel screw in to see if it helps. This will lean the pilot cicuit and tell you if the pilot jet is too rich. If the bike idles best at less than 3/4 turns out on the fuel screw, the pilot is too rich and you need to go a step leaner.
  • AUS_WR450
Posted May 03, 2006 - 02:04 AM
Whilst on this subject of hotstart setup and jetting, I have a question. Once my bike is nicely warmed up after about a 5 min ride, if I pull in the hotstart lever and the revs rise. Does this suggest that my pilot circuit is too rich. (the bike has no apparently jetting issues across the rev range).
Nigel
  • MountainMax
Posted May 03, 2006 - 02:52 AM
Thanks for the explination of the hotstart but how does it lean out the carb? what circuit does it affect? and yeah, sounds like you trouble is in the pilot circuit.
  • Baron Von Beard
Posted May 03, 2006 - 07:38 AM
The hot start cable is connected to a plunger in the carb. When you pull the lever, the plunger opens up and allows fresh air into the carb to lean out the mixture. It does the exact opposite of a choke.
AUS_WR450 - Whilst on this subject of hotstart setup and jetting, I have a question. Once my bike is nicely warmed up after about a 5 min ride, if I pull in the hotstart lever and the revs rise. Does this suggest that my pilot circuit is too rich. (the bike has no apparently jetting issues across the rev range).
Nigel
This could be an indication that the pilot is set too rich. Try turning the fuel screw in a 1/4 turn at a time while it's nice and warmed up and idling and see if the rpms go up. Refer to the sticky at the top of the jetting forum to get the pilot jet and fuel screw tuned up. Having this circuit tuned well will aid in starting (hot or cold) as well as give you better low end response.
