XR650R Wheel Bearing Removal Tips
8 replies to this topic
  • jond8
Posted May 01, 2006 - 02:46 PM
I am gearing up to replace the seized wheel bearings in my pigs rear hub... found this little gem somewhere floating in the online:
http://www.vjmc.org/...ps/bearings.htm
:crazy:
Cheers,
Jon
  • motomonte
Posted May 01, 2006 - 02:52 PM
The concept sounds good,it should do the same job as an expanding collet that is used for that very same job. :crazy:
  • jond8
Posted May 01, 2006 - 03:09 PM
where can we find this expanding mandrel? Is is the 85$ jobby that Honda sells?
  • motomonte
Posted May 01, 2006 - 03:23 PM
You should try a hardware store where they sell drills taps and shop equipment,they usually come as sets of different sizes tough you could get them individually,most surelly they will cost less than a factory (honda) unit.If you cant find it locally try McMaster Carr or Grainger.
  • qadsan
Posted May 01, 2006 - 03:59 PM
That's a great tip!
I've banged out wheel bearings plenty of times with a sharp edged drift, but it got to the point where I needed a better solution, so I bought some pilot bearing pullers and modified them to fit various bearing applications for quick and simple removal. I modified my pilot bearing puller to work with a slide hammer (turning it into a 'Blind Bearing Puller'), so it's simply a matter of getting the jaws locked onto the inside edges of the bearing and giving it a few whacks with the slide and out they come :crazy:
  • jond8
Posted May 01, 2006 - 04:01 PM
another good one:
http://www.4strokes....osse/wbremover/
  • motomonte
Posted May 01, 2006 - 05:29 PM
another good one:
thats what im talkin about, see the price?way cheaper waaaay easier,it pays for itself the first time you use it. :crazy:
  • jond8
Posted May 03, 2006 - 10:23 AM
Well, finally got my bearings out... had to weld a piece of rod to the large bearing and use a press to get it out.. it was galled/rusted into place... Then I was able to reach through and press out the small bearing
Anybody have an opinion on not re-installing that damn sleeve between the bearings? Seems like this might make the next bearing replacement much easier....
  • motomonte
Posted May 04, 2006 - 04:28 AM
Jond that sleeve acts as a spacer to keep the bearings from moving inwards when you tighten your wheels,it also prevents them from being crushed by the torque.
Washington
  • Hot  32 replies
  • 9 replies
  • 3 replies
  • Hot  60 replies
  • 17 replies
