Is Amsoil 20/50 Synth Car oil ok?
4 replies to this topic
  • Ga426owner
Posted May 01, 2006 - 09:40 AM
I found a case cheap cheap cheap....This is blue cap 20/50 Fully synth car oil. Is it ok for my 06?
I could not find results by search -
thanks
  • BC61
Posted May 01, 2006 - 09:46 AM
Look on the labe where it says "API service" if it has friction modifiers then you could encounter clutch slippage issues. If it doesn't say anything about modifiers then you are ok.
Posted May 01, 2006 - 12:22 PM
Their MCV Synthetic Motorcycle oil is much better, because it's capable of living in the transmission better than most oils are (in fact it's also labeled GL-1), but as long as the API service label does NOT say ECII, you should be OK to use it as you would the old Mobil 1 red cap. The only concern would be viscosity shear down.
  • Ga426owner
Posted May 01, 2006 - 03:48 PM
I figure every 2-3hrs riding time for oil change should be good. No ECII anywhere on the container
  • barch88
Posted May 01, 2006 - 04:07 PM
Damn, thats a early oil change if you ask me. I usually go 5-6. Or sometimes just every 2 days of riding, depending how much/hard I ride. :crazy:
