oil consumption
21 replies to this topic
  • ghoti
Posted May 03, 2006 - 05:02 AM
#21
ThanX for all the good advise. Before I re-install the smog devices back on and run to the "friendly dealer", I would change the oil with accurate amount (2.2). I would than start monitoring the level again.
ThanX again, Yuki
The key to checking the oil for comparison is that the parameters are the same. For example if you idle your bike for 5 minutes, shut it off and check the oil level after, say 30 seconds. Do that every time. Do not compare that reading to one after riding for 30 minutes.
  • TimBrp
Posted May 03, 2006 - 05:26 AM
#22
New engines should not "burn" oil however ALL engines consume oil. Not anywhere near 1/2 a qt. though. I'm betting on a bad reading.
  • 17 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 22 replies
  • 9 replies
  • 3 replies
