I Need A 100 Watt Or + (180watt). Stator For My Yz450f 2006
11 replies to this topic
  • MILODIRTRIDER
Posted April 30, 2006 - 07:34 PM
SOMEBODY KNOWS,WERE I CANT BUY A COMPATIBLE "100 OR 180 WATT "STATOR" FOR MY 2006 YZ450F. I LOOKING TO MODIFIED IN A STREET LEGAL BIKE;BECAUSE THE "2006" YZ450 STATOR IS DIFERENT TO THE "2005"YZ450F STATOR
I NEED HELP. THANKS FOR YOUR ATTENTION.
:crazy:
  • Zique
Posted April 30, 2006 - 07:43 PM
Try Ricky Stator, Baja Designs, or E-line. Pricey, but good.
  • rooster wrooster
Posted May 01, 2006 - 04:34 AM
Good luck. As of last month none of those had anything for an '06. I had to go with battery lighting until someone comes out with a stator.
  • KTMKarl
Posted May 01, 2006 - 08:53 AM
Your not alone! I'm considering getting my hands on a 250f just so I can run my night race set-up! I hope somebody comes up with something soon.
  • vegasdesertrat
Posted May 01, 2006 - 08:59 AM
I just received a reply from e-line and they currently have no plans on making one. Bummer!
  • MILODIRTRIDER
Posted May 01, 2006 - 10:53 AM
rooster wrooster .THANK YOU FOR YOUR QUICK RESPONSE; SEEING PICTURES OF YOUR MOTORCYCLE WAS OF GREAT HELP. I DON'T KNOW IF IT'S TOO MUCH TO ASK BUT IT WOULD BE OF GREAT HELP IF YOU COULD TELL ME WHAT KIND OF BATTERIE YOU ARE USING TO RUN THE LIGHTS? THAT IS A BIGGER GAS TANK RIGHT?
I'M GLAD TO KNOW THAT I'M NOT ALONE ON THIS MISSION !
THANK YOU AGAIN FOR ALL THE HELP.
MILODIRTRIDER
:crazy:
  • rooster wrooster
Posted May 01, 2006 - 12:56 PM
It's a sad sad little lighting kit. But if you just want to be street legal and ride only during the day then it gets the job done. Don't even bother getting it if you really want to ride at night. The battery is a 12v NiCad rechargeable and it lasts a whole 12 minutes on high. I don't know how many watts the light is though, but it isn't much. Here is a picture of the kit.
Here is where you buy it from, its the universal enduro kit. $299
http://www.sicassrac...ct=New_Products
The tank is the IMS 3.1 gallon.
  • Zique
Posted May 01, 2006 - 06:38 PM
I have done the same "battery only" set-up on my 426. Same story. I just did enough to get street legal, but it doesn't power the lights for more than 20 min. I set-up an LED taillight so it will run for days w/o draining. The headlight however draws way too much to do any good. I went with a tiny 1.2 ah SLA battery and mounted it in the air box.
  • tlrace
Posted October 01, 2007 - 11:52 AM
I also have been looking for a stator for my o6 yz 450. I was told that you can make a wr 450 stator work. with some modifications.
Posted October 01, 2007 - 12:12 PM
I would doubt that, but if you can find any solid info to that effect, I'd like to see it.
I believe that the WR stator is larger in diameter than the YZF unit. That means it would require the WR flywheel, and the WR left hand cover to mount the stator in. The cover will fit, the YZ engine, but the flywheel requires at least the left side of the WR crank (which will also fit). Believe it or not, this is an improvement over the previous YZF/WRF interchangeability situation, which essentially was that you needed to swap the entire WR crankcase/transmission assembly into a YZ in order to do this.
  • Wiz636
Posted October 01, 2007 - 12:25 PM
This is a pretty good thread on lighting. Good luck....keep us updated if you find out anything new.
http://www.thumperta...651#post4225651
  • tnl
Posted October 01, 2007 - 03:06 PM
:confused:
Call these guy's: http://www.electrosp..._yamaha_mx.html
They don't show anything newer than a 2005 yz 450f but the data base might not be updated online? Also, it's output is only 50 W. I purchased that unit and I'm very satisfied with it even at night for $180 can't go wrong. Get a LED bulb for the tail/run/brake light so the headlight isn't starving. Also, there are a ton of threads/posts on this subject :confused:
Motocross
  • Hot  491 replies
  • Hot  28 replies
