How is this chain?
7 replies to this topic
  • barch88
Posted April 30, 2006 - 05:55 PM
http://www.motosport...|32087&id=97271
Try to copy/paste the link. It is a DID 520 ERV2 X-RING GOLD CHAIN 120 LINKS.
To replace the stocker. Will it fit fine with the stock sprockets, is there any other chain thats better?
-Mike
  • kawirider
Posted April 30, 2006 - 06:08 PM
I believe any 520 chain you buy will fit your bike. You will probably have to cut it so you might want to get a chain breaker while you are at it. Since x-rings are wider you may have a problem with it rubbing somewhere but I wouldnt worry about it.
  • Zique
Posted April 30, 2006 - 07:09 PM
I believe it should be fine. I don't think they changed the size of the chain for the 450. My 426 is 114 links. So you will have to be cutting it down a bit. The chain itself is an excellent chain.
  • Bigcr
Posted April 30, 2006 - 07:26 PM
Great chain. I've run them for the last 5 years and love 'em. I'll be putting one on my '07 YZ450. I may have to go from Bigcr to Bigyz, but then I'll drop my post count.
  • Zique
Posted April 30, 2006 - 08:30 PM
:ride: But your sooooo close to silver member :ride:
Come on Bryan, let's give him a name change at no extra charge...(I'll root for you buddy!) :crazy:
Posted April 30, 2006 - 09:39 PM
Believe me, post counts are overrated. :crazy:
The ERV2 is a very good chain, but IMO, the Regina ORH is a better one (my experience is that they run freer and last longer), and you can get them for as little as $70. Here's one example. Scroll down to the chain packages.
  • barch88
Posted May 01, 2006 - 06:27 AM
Thanks, and I will need a chain cutter guys?
Posted May 01, 2006 - 07:27 AM
Yes, and the type I recommend is the "Reynolds" style, like the Regina #805000 shown on This Page . This one sells for about $30, and will break the strongest 5/8" chains easily for years to come. Just be careful who you loan it to.
Be advised that the master links on the good chains have to be pressed together, too. The tight fit is what makes them strong. As you can see on the posted page, there are tools for that, too, but you can work around the problem with vise grips or C-clamps, or something if you want to. Be sure you get it assembled far enough so that the clip drops all the way into the groove cleanly, and don't forget to put the seals on the master link.
  • 0 replies
  • Hot  47 replies
  • Hot  36 replies
  • Hot  38 replies
  • Hot  30 replies
