Do you guys degrease your chains?
12 replies to this topic
  • minion
Posted April 30, 2006 - 12:05 PM
Hello,
I made the mistake of using some really crappy chain lube I had laying around on my chain early on when I bought my wr450. Well, the stuff never wore off, put has continued to collect dirt, sand, and every other nasty thing a trail can throw at it.
Do you guys ever take your chain off and soak them in something to clean them up? Or am I being too picky, and I should just ride it and be happy? The chain on it is the stock O-ring chain that came with it, and I've only got about 400 miles on the chain.
Thanks,
M.
  • Numskull
Posted April 30, 2006 - 03:34 PM
I sprayed my chain with chain lube once back in the '80s and it was the nastiest stuff, super sticky gunk.
I just use motor oil every once in awhile. You could try motor oil on it a few times and see if that wont clean it up, or clean it with some gas. Just dont blow your self up :crazy:
I wouldnt use solvent as that could damage the orings.
  • odonnks
Posted April 30, 2006 - 04:46 PM
Try kerosine or wd 40
  • 642MX
Posted April 30, 2006 - 04:48 PM
I use mineral spirits.
  • new2blu
Posted April 30, 2006 - 06:29 PM
Use kerosene it is much safer to use than any other type of highly flammable cleaners. Just one little spark with the high flame stuff and your day is ruined!
  • tony1970
Posted April 30, 2006 - 09:47 PM
Kerosene or diesel fuel, whatever one is cheapest now.
  • tmckeown
Posted April 30, 2006 - 11:25 PM
Hi,
Diesel fuel and paint brush :crazy:
Timo Mc
  • OneToGo
Posted May 01, 2006 - 02:32 AM
I read recently where Kero can damage a chains O-rings, is this true. [can anyone verify if WD40 has kerosene in it?? :crazy:] I think the story was in a recent Dirt Rider mag - some long desert ride. Also ,someone used WD40 on an O-ring chain and it proceded to self destruct.:ride: The WD 40 washed all the lube from the O-rings - may be they forgot to lube it later??
Personally, I use a good quality wet spray lube, let it soak (on the bike) wipe excess off with a rag. Then dry lube over the top so dirt does not stick..
Seems to work a treat.
Both a O-ring safe non-tacky spray lubes.
My .02 worth
  • MountainMax
Posted May 01, 2006 - 02:37 AM
I have searched here on this subject myself, there are lots if info and personal preferances out there too, but i too could not find good solid info.
  • Matty05
Posted May 01, 2006 - 03:08 AM
Your chain should still be in very good condition at 400miles.
I don't think too much of a clean is necessary, it is sealed, and any contact with solvents / cleaners / wd40 will only melt away the lube that the o-rings are there to seal in.
Just a quick wash with the hose and maybe a quick brushing of the sideplates is needed, for cosmetics only. If you use a good chain wax / dry lube, dust and dirt doesn't really stick. The lube doesn't really do much, you are just stopping the chain from rusting.
  • J_DOGG
Posted May 01, 2006 - 08:57 AM
to clean - Gas or WD40...
To keep rust free - I only spray WD40 on my chain..... nothing else.
  • WGP
Posted May 01, 2006 - 09:09 AM
I clean with Kerosene and (really)soft brush, let dry, soak or apply heavy coating of 10-40w motor oil (every other ride).
My new o-ring directions said wash off the factory lube with HOT soapy water, otherwise dirt will stick to it like crazy and shorten the life.
When in a rush after getting wet (either washing or wet ride) squirt some wd-40 on it.
I once watched my new chain rust right in front of my eyes when i didn't lube it after a wash :crazy:
  • Captain Bob
Posted May 01, 2006 - 09:31 AM
Numskull....
Gas is a solvent!
Bob
