K&N Filter
8 replies to this topic
  • Yamaster
Posted April 29, 2006 - 06:03 PM
I wanted to get a K&N filter for my 05 wr450, but dont get how it mounts. I want one because all of our quads (sand) use them and I wanted one for my 450. Any clue to how it mounts?
  • 642MX
Posted April 29, 2006 - 08:07 PM
Do yourself and your intake valves a favor and use a good quality foam filter on your WR. Do a search on K&N filters, they are proven to pass dirt and cause problems.
  • odonnks
Posted April 30, 2006 - 04:06 AM
The problem I've seen with the one for a WR is it is a 2 piece, Like this
http://www.knfilters.com/dirt_bike.htm
The top is a separate piece. Now you have two sealing surfaces to contend with.
I have heard of the same issues.
I do run the single piece ones on my quad and have in my cars.
  • Yamaster
Posted April 30, 2006 - 03:35 PM
What do you think the trucks in baja use along with some quads and bikes?
  • 642MX
Posted April 30, 2006 - 04:18 PM
I could care less what everybody uses in baja. I use products based on what I have found thru research and real world experiences, not on what the quadtards in the desert think is best. :crazy:
  • WildRide
Posted April 30, 2006 - 07:39 PM
Personally I wouldn't use a K&N in my lawnmower. They are not good in dusty conditions.
http://home.usadatan...5011/SPICER.htm
  • CJ06WR
Posted April 30, 2006 - 08:54 PM
Damn Wild Ride.....That was a lot of good info. It will definitely keep me from putting a K&N in my bike....
  • creeky
Posted May 01, 2006 - 04:37 AM
A long time ago when I first started riding XRs, I tried K&N. I had problems with the sealing surface, saw streaks of crap in the airbox when I removed the filter. I tried several greases and even made my own gasket to replace the crummy stick-on gasket that came with the K&N, no luck, got tired of screwing with it and bought a UNI and have been using them ever since with no problems.
  • EXCKiller
Posted May 02, 2006 - 01:24 PM
I had put a K&N in my DR 650 Dual Sport
First I had to re-jet LEANER :cheers:
I had constantly dirt / dust inside the intake manyfolds :crazy:
Oil consumption increased, cylinder and piston and rings ruined!! :lol:
K&N = no good! :ride:
After the engine rebuild I use a Twin Air, no more dirt past the filter, lots cheaper and easier to clean. :ride: Forget K&N!!! :cheers:
I asked my LandRover tuner about his opinion on K&Ns: "If you can look trough it, dirt will go through it.." rightly so! :cheers:
I got in contact with K&N, cylinder and piston and filter went to the US (from GER!). Of course I had ruined the filter using "other than K&N filter oil" (such as Twin Air or No Toil), they send me a new filter which of course I never installed.
SAE has got a standard out for the performance of automotive engine air filter (do not have the procedure number at hand). Recommendation is an efficiency of 99,9% under dusty (=OR) conditions. K&Ns never make that! If you want, I can figure out the respctive procedure number. Contact them and ask for their results!!!!
EXCKiller
