50 pilot
8 replies to this topic
  • Darth Wader
Posted April 24, 2006 - 03:25 PM
This may be a silly question but, has anyone tried a 50 pilot jet? Indy's chart basically sticks to a 48 for most situations. Does the 50 make it too rich off the bottom even in colder weather?
Thanks for any insight.
  • Indy_WR450
Posted April 24, 2006 - 04:40 PM
Matty and Tarflee use a 50 pilot. It is OK if you are running a leaner main and needle settings with heavy mods. I just find it too rich for most everything but seriously cold weather. Try a JD blue needle before going to a 50 pilot. The needle tip taper overlaps with the pilot circuit so needle clip position and needle tip size make a difference in the overlap. :thumbsup:
  • pkcof
Posted April 24, 2006 - 05:12 PM
I'm assuming that you're using a #48 pilot now - just out of curiosity, what position do you have your fuel screw ? If it is between 1 ~ 2 turns out the going to a #50 will definately richen it up to the point where you may not have much adjustment left with your fuel screw ...
  • Matty05
Posted April 24, 2006 - 11:38 PM
Nah mate, back to a 48, just about a 45 in the monsoon build up (very hot and humid).
Vacuum plate was on upside down. I was actually using a 52 there for a week or two!
  • tmckeown
Posted April 24, 2006 - 11:50 PM
Hi,
I got a 50 on my bike.
It really depends also on mods you have done
Timo Mc
  • Darth Wader
Posted April 25, 2006 - 08:00 AM
What did you do (intake wise) to get a good mix ratio with that pilot?
  • tmckeown
Posted April 25, 2006 - 08:21 AM
HI,
I have a twinair gage and filter, then you should get good fuel screw that can be turned with out tools. I recommed Stealth, I tried Zip-Ty but O-rings they use are crap and after first time I warm engine up it shrinked.
Head is also ported
Timo Mc
  • MTRider
Posted April 25, 2006 - 02:10 PM
Where can the Stealth fuel screw be found? I did some quick searches and found nothing.
Thanks for your help
  • tmckeown
Posted April 25, 2006 - 11:07 PM
Hi,
From here:
http://www.stealthracingtech.com/
Timo Mc
