Changing out a regulator for a regulator/rectifier...
9 replies to this topic
  • TallBoysWRF
Posted April 24, 2006 - 08:16 AM
I want to turn my bike's electrical current into DC from AC but I'm wondering what I need for a rectifier? Are they basically all the same or do I need to look for certain features. So basically will most any 12V rectifier work? Thanks.
  • simon@vic
Posted April 24, 2006 - 09:15 AM
what bike?
  • TallBoysWRF
Posted April 24, 2006 - 09:47 AM
well I was wondering if there was a general rule or anything.... but my bike is a 99 WR400.
  • simon@vic
Posted April 24, 2006 - 09:53 AM
get the generic Honda one.
the guy at your local Honda shop should know the one. it is on about 100 Honda's.
cheap, reliable, easy to come by.
good luck!
  • TallBoysWRF
Posted April 24, 2006 - 10:39 AM
Any idea what they cost? I was looking at the rectifiers for the 450's and yamaha wants like $68 or something outrageous for them.
  • WR450F_RDR
Posted April 24, 2006 - 05:18 PM
you can get a generic one from Trailtech or from Bajadesigns. I just converted my WR over to all DC power for dual sport reasons. I purchased the Trailtech unit and it works great. There is a mod that needed to be done on my stator in order to convert it to straight DC power, I do not know if it would be the same for yours. I did the mod myself, pretty easy.
  • toyota_mdt_tech
Posted April 24, 2006 - 05:56 PM
1/2 wave or full wave? A rectifier is just a fancy name for a "diode", and diode inline on either side will convert your AC to DC, but this will only be a 1/2 wave setup and there would be a millisecond period during each cycle where the voltage will be zero, though, your probably never notice it. I recommend a full wave as your system is probably single phase. Moose sells a rectifier, it appears to be full wave. a full wave rectifier will have 4 wires, 2 will be your AC inputs, the remaining 2 will be your DC output, ie postivie and negative. Its mounted to an aluminin heat sink to dissapate the heat from the diodes. Do a search for "full wave rectifiers" to get you a real good idea what your up against. This is such an easy conversion. I found this online: http://www.technolog...erto/bridge.htm
  • TallBoysWRF
Posted April 24, 2006 - 06:01 PM
I've also read that I need to run a battery or a capacitor to "filter" the current. If I run a capacitor (I don't really need a battery) would the lights still dim at idle?
  • jbrooks26
Posted April 24, 2006 - 06:09 PM
There is a chance your lights may still dim with just the capacitor. If you want a constant light, you will need a regulator also. I am not familiar with this type of conversion, but I am an electronics technician. The capacitor is used to simulate a battery and it also acts as a filter to help smooth out the current. It will help prevent spikes, however the voltage output will still vary with the input to the rectifier. This is where the regulator comes in, it keeps the voltage from rising past a pre determined point. If that point is lower than the lowest output of the rectifier then your lighting will be constant. Hope this helps,
  • creeky
Posted April 25, 2006 - 04:57 AM
For my '00 XR250 I bought a battery from, look under 12V robot batteries, and generic regulator/rectifier on E-Bay, works great. Total cost was $35.
