96 XR600 runs badly at constant throttle settings
6 replies to this topic
  • Teamclaw2001
Posted April 23, 2006 - 09:40 PM
I just picked up a used 96 XR600. It starts easily but runs poorly at any throttle setting over 1/4. I've cleaned the carb, checked the jets. Where should I look for the problem. It goes down the road good but cuts out and sputters at any constant throttle settings over 1/4.
  • targetdrone
Posted April 23, 2006 - 10:06 PM
Clean your carb better. There are many passages in the carb that can get clogged, as well as the jets. What you describe is a clogged carb.
  • creeky
Posted April 24, 2006 - 03:49 AM
Sounds like it is running lean, might try a larger main jet.
  • bork
Posted April 24, 2006 - 05:45 AM
Go down a street for a real short test ride after bike is up too full running temp & run without air filter for one quick run. Does it clear up any ? ( If so, too rich) (If runs worse, Too lean) If you know it has a updated billet choke plate, you can choke a little to find out rich or leaness. But if you have stock choke plate, it has a history of breaking off & a little piece may get sucked in and ruin topend(thus wallet). Replace it now if not yesterday!
  • Teamclaw2001
Posted April 24, 2006 - 06:20 AM
I tried a #160 main jet, it had a 152. The problem didn't get any better.
  • atkxr600
Posted April 24, 2006 - 08:51 AM
On my 86 XR600 motor, I had a similair issue. I worked on it for a time, with no luck. Then took it to a friend who's a mechanic at the local dealer. He had for a few days, then called me to say the only issue he could find was the stator checked out a little low. It was in spec, but on the low side.
But it was the only thing he could find. We took a shot and put a new one on it, then it ran like a top.
Hope it helps.
  • Teamclaw2001
Posted April 26, 2006 - 08:44 PM
Thanks for the help. Cleaned the carb again, runs fine now.
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
  • 4 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
