Resistace - exciter coil (stator) XR600
5 replies to this topic
  • Fredda
Posted April 23, 2006 - 11:22 AM
I have a -93 year XR600 and need to know what the resistance of the exciter coil (the stator suppling the ignition) should be. My manual says 230-320 ohms, but I think it is for a earlier modell so I'm not sure.
And if anyone knows what the diameter of the copperwire should be it would also be greate. (have measured, but I don't get it to be right.)
  • moleculo
Posted April 23, 2006 - 06:19 PM
The pre-'91 exciter coil spec is 230-320 ohms. The '91-on spec is 50 to 150. Typically they show right around 90 ohms between the black/red wire & chassis.
  • Fredda
Posted April 24, 2006 - 12:04 AM
F'ck!
Just ripped off all the wiring of my coil, showing 80 ohm :thumbsup: :thumbsup:
So an advise to all TT-members, check that you got the right manual before acting.
  • cleonard
Posted April 24, 2006 - 10:39 AM
My 93 looked good when I connected the ohm meter. However, it was still bad. My symptom was primarily difficult starting when hot. It got to the point where I had to push start it when it was hot. I could kick it forever and it would not start. The problems only seemed to occur while the engine was hot. Even when hot, the meter reading was correct. I rewound, and now it starts easily.
  • suharianu
Posted April 24, 2006 - 09:45 PM
How many turns and what wire gauge did you use?
  • cleonard
Posted April 26, 2006 - 02:00 PM
I used 33 gage magnet wire. I got it a surplus place for $2. I wouldn't go any bigger than 32 or smaller than 34. Smaller wire is weaker and more prone to breaking. No idea how many turns, but I put as many as would fit. I can't wind it nearly as well as the machine winding on the stock unit, so I doubt I have as many turns as stock.
It's been working for 2 years.
  • 3 replies
Honda XR650L 2016
  • 0 reviews
  • 17 replies
  • 4 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
