Oil change help !!
6 replies to this topic
  • srsonicseller
Posted April 22, 2006 - 05:16 PM
I just got a 2003 WR450, did oil change today but have questions. After changing filter and checking screen in front below radiators making sure it was clean as per owners manual - I installed new oil, measured correct amount per owners manual. After I started bike for a couple minutes , I pulled dip stick and oil started coming out? What is going on? :thumbsup:
  • redmansz400
Posted April 22, 2006 - 05:40 PM
on the dipstick or by the quart?
  • jerryls
Posted April 22, 2006 - 08:28 PM
Turn off the engine when you check the oil.
Jerry
  • trailordune
Posted April 22, 2006 - 09:26 PM
sounds like you put too much in if bike was not running when you checked it.
  • redmansz400
Posted April 22, 2006 - 09:53 PM
when i picked up my new suzuki 400 from the dealer i checked it and they had the crankcase and the resivour full. check the level while it is hot but not on
  • David37
Posted April 23, 2006 - 12:05 AM
After you start your bike, turn it off and let your bike sit for a 3-5 minutes before you check the oil level.
  • OlaGB
Posted April 23, 2006 - 12:17 AM
Sounds like you didnt drain out all the oil, or put in more oil than the specs tells you to..
