Assembling transmission...
4 replies to this topic
  • xjruss
Posted April 22, 2006 - 02:21 PM
The manual says "spin the shafts and turn the shift drum by hand to check operation"...
For those of you that have been through this, have you really been able to turn the drum by hand and shift through all the gears? I can hardly turn it at all... it just seems like there's not enough leverage.
Thanks.
  • lightestYZF
Posted April 23, 2006 - 06:17 PM
I too was not able to spin by hand but I was careful all three times have fixed gearbox and it worked once together - at least for a while but that is a different story.
  • FFRacing79
Posted April 23, 2006 - 07:21 PM
What I do before I put the "ratchet" assembly into the end of the shift drum, I use a 12mm T-handle to operate the shift drum while I spin the trans. Works for me! Tdub
  • mkporn
Posted April 24, 2006 - 07:29 AM
This is the only way^^^^^ :thumbsup:
  • scottpb33
Posted April 24, 2006 - 11:48 AM
I test by gettign a second person and hook up my cordless drill with a socket and have the person go at a slow speed while I shift and check that all is workign as it should
  • 10 replies
  • Hot  36 replies
  • Hot  50 replies
  • Hot  47 replies
  • Hot  38 replies
