Measuring fork oil level
6 replies to this topic
  • MikeZ
Posted April 19, 2006 - 07:31 PM
XR650R.
So I flushed all the old, icky fluid out with ATF. And am in the process of reinstalling some really nice 2.5 wt.
I know the manual calls for 4.7" from top with the fork collapsed, springs out. My question is what does "collapsed" mean?
There is a point where the forks want to stop naturally, but if I push hard, it can go another 3/4 inch or so. Obviously, this changes the oil measurement.
Thanks all,
-Z
  • Max Power
Posted April 19, 2006 - 07:53 PM
"Collapsed". Hmmmm.....
  • MikeZ
Posted April 19, 2006 - 07:59 PM
Thanks Max.
I have the service manual, but I always like looking at your avatar...
Never mind. I am a total dumb@ss. I was running into the fork boots...
Problem solved.
BTW, I also learned, not to fully extend the fork as you are pumping new oil through... BIG MESS!!
-Z
  • Max Power
Posted April 19, 2006 - 08:07 PM
Thanks Max.
Problem solved.
-Z
I see. More good info HERE. Make sure you read the whole thread. Some corrections along the way.
  • XR4DEZ
Posted January 18, 2007 - 09:10 PM
Isn't the adjuster collar shown in the pic upside down?Or is that one of the corrections?
  • abby
Posted January 19, 2007 - 04:52 AM
Any particular brand or flavor of Automatic transmission fluid?
Just getting ready to take mine apart to add heavier springs. I'd like to flush the old stuff, but I've always used the same oil I was putting back in, just bought extra to do that.
  • tirebiter
Posted January 19, 2007 - 05:34 AM
Thanks Max.
-Z
If you've extended the fork till oil flows out of the hole in the bottom of the inside fork tube, be sure to pop up the dust cover and clean out any oil trapped between the seal & dust cover. I forgot to do that once, the oil eventually worked it's way out, but I thought I had a blown seal..
  • Hot  35 replies
  • Hot  60 replies
  • Hot  29 replies
  • 3 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
