Fuel Inlet
1 reply to this topic
  • TARFELE
Posted April 19, 2006 - 04:57 AM
On my 03 the fuel inlet on the carb faces towards the rear of the bike instead of towards the tank. If looking at the inlet it is in the 1:00 position this causes me a problem with fuel flow from the Acerbis tank because the fuel has to run uphill then down and the fuel line can become pinched. I have not had any issues yet but that is because I am using very stiff fuel line.. I know on some bikes the FCR carb has an inlet that swivels but mine does not move. Does anyone know a solution to getting it to move? I am afraid that the inlet is pinned in and forcing it will cause me a problem.
  • OringGroove
Posted April 19, 2006 - 05:20 AM
You could try placing a spring around the fuel line so that the line does not kink! It will also protect the line!
