Nitrogen in Rear Shock. Can air be used?
51 replies to this topic
  • xnofriendsx
Posted April 18, 2006 - 09:36 PM
I was curious to see why Nitrogen is put into the rear shock. Does plain ole air just get contaminated?
Would it be harmful to put air in the rear shock?
My mountain bike stuff just uses air from my shock pump.
Just curious cause i want to check the pressure, but i know it will probably lose a lot of pressure and it will probably be $$ at my local shop to refill the Nitrogen.
But before i check it i just wanted to know why Nitrogen is used and if air could be substituted.
Thanks for any info.
  • FTT
Posted April 18, 2006 - 09:47 PM
Nitrogen is an inert gas which remains a gas at extremely high pressures. Shop air from a compressor has moisture in it which leads to internal corrosion of the shock over time.
  • kd5qoq
Posted April 19, 2006 - 03:28 AM
Believe me it's nitrogen for a reason and it's usually just a few $$$ to get it charged.
  • beezer
Posted April 19, 2006 - 06:45 AM
Air and oil under pressure can diesel.
A good proctologist would be needed after and episode like that.
Posted April 19, 2006 - 06:47 AM
Nitrogen is not an inert gas. It is, however, very inactive, chemically, and does not at all readily involve itself in chemical reactions. You could say it's somewhat inert. Air, on the other hand, contains oxygen, one of the original busy bodies of chemistry, along with carbon dioxide and several other gases, and even if it were dried, it's more reactive than nitrogen by itself, so the point made is the same.
Nitrogen is also more compressible than other air gases are, which allows it to be put in a smaller space at a higher pressure, and compressed to a higher degree without the pressure rising to a dangerous level.
  • NYMXer
Posted April 19, 2006 - 07:54 AM
Using air rather ethan nitrogen is dangerous due to the small volume of highly compressed gas. When the air expands due to heat, it could explode the reservoir. A nitrogen recharge is only about $15 at a dealer.
  • DrThumper
Posted April 19, 2006 - 08:14 AM
Gotta agree with Gray, I couldn't have said it better. Air is mostly nitrogen, but the low percentage of oxygen (12%?) will cause rubber seals to oxidize, moisture in the oil to oxidize, etc.
Just make sure the shop is reputtable (sp?)....and doesn't just put in compressed air.
Posted April 19, 2006 - 09:22 AM
But I did omit the fact concerning the thermal expansion of air, too.
  • DrThumper
Posted April 19, 2006 - 10:47 AM
Also, by its nature, nitrogen doesn't absord water vapor as much as O2 or air, has less partial pressure (more compressable and purges heavier gases)....also if we look at nuclear-phyllic attacks with a N2 compounds........don't get me started...
  • 97chevy
Posted April 19, 2006 - 02:06 PM
I was ALSO thinking they put in nitrogen because the nitrogen molecules are bigger than air molecules. The larger molecules have a harder time going through the rubber seal, so the charge lasts longer. That is why they put nitrogen in airplane tires. Atleast that is what I have heard.
  • FFRacing79
Posted April 19, 2006 - 05:45 PM
The main reason Nitrogen is used is because it is less likely to change when heated. ie. if air was used and you started with a pressure of 140#, by the end of the moto the pressure could be as high as 160#, where the Nitrogen filled shouck might only gain 5#. The same reason we run Nitrogen in our tires on the Mile ovals. Tdub
  • theclone
Posted April 19, 2006 - 07:15 PM
:thumbsup:
I was gonna say the same thing. Tire stores also use N2 because people are too lazy to check the air pressure in their tires, and low tires lead to blowouts.
  • JetBlueJoe
Posted April 20, 2006 - 04:57 AM
I've always heard Nitrogen was used in aircraft struts because it is thermally stable in addition to it's cleanliness.
What is the normal precharge of the shock on the 450, should it be checked more than annually? Or any bike for that matter I would imagine they leak down some over time.
  • DrThumper
Posted April 20, 2006 - 06:04 AM
Nitrogen is bigger than air? Nitrogen is found in the form of N2, thus its 14 daltons in weight (or weight, however you want to look at it), "Air" is (approx) 76% Nitrogen, 15% Oxyegen (O2 = 18 daltons) and the rest is a mix of other gases (CO2, etc). Add it up, "Air's" average size is just larger than N2 alone.
  • treehopper
Posted April 20, 2006 - 01:38 PM
I use argon because I have argon. Is there anything wrong with argon?
  • jeffboyd47m
Posted April 20, 2006 - 02:13 PM
It would also be tough to find a compressor that would charge a shock at 150-175 PSI.
  • xcape
Posted April 20, 2006 - 02:17 PM
Any scuba diving shop can do 5000 psi air
  • jamieyz426f01
Posted April 20, 2006 - 02:28 PM
if you put standard air from a compressor in your shock I'm guessing the hike in pressure when its warm would blow the seals out. Argon is inert but I'm not sure whether it would react to heat change as well as nitrogen :thumbsup: :thumbsup:
  • MotoGoalie
Posted April 20, 2006 - 02:32 PM
So are there 'alternative' places you can charge your shock up other than a M/C shop?
  • Numskull
Posted April 20, 2006 - 02:34 PM
I agree :thumbsup:
Contrary to some claims, nitrogen does not diffuse through tire rubber more slowly than air. Air is mostly a mixture of nitrogen and oxygen, and the nitrogen molecules are smaller. All else being equal, smaller molecules diffuse through porous substances more quickly.
Pure Nitrogen is an inert gas, meaning it does not change state very easily or chemically react with other materials very easy. :thumbsup:
  • Hot  113 replies
  • On January 15, 2017
  • 10 replies
  • Hot  47 replies
  • Hot  36 replies
