1999 to 2006 WR wheel swap?
2 replies to this topic
  • Frostbite
Posted April 18, 2006 - 12:41 PM
Does anyone know if they're interchangeable? I'm looking at a new WR 450 and have 3 sets of wheels for my 99 WR and am hoping they'll fit.
Thanks
Frosty
  • bluebike1999
Posted April 18, 2006 - 02:54 PM
1999 rear wheel
5ET-25311-00-00 HUB, REAR 1
2 5ET-25317-00-00 SPACER, BEARING 1
3 93306-27205-00 BEARING 1
4 93306-07202-00 BEARING 1
5 93106-30044-00 OIL SEAL 1
6 93106-30045-00 OIL SEAL 1
7 99009-45500-00 CIRCLIP 1
8 94421-18610-00 RIM (2.15-18) 1
9 5GS-25304-00-00 SPOKE SET, REAR 1
10 94111-18008-00 TIRE (110/100-18 64M D739) FOR ZAF DUNLOP 1
11 94212-18188-00 TUBE (110-140/80-100-18 M/C) FOR ZAF DUNLOP 1
12 94309-18146-00 BAND, RIM (2.15-18) FOR ZAF DUNLOP 1
13 3JE-25394-00-00 SPACER, BEAD 2
14 4XM-25364-00-00 DAMPER 2
15 5GS-25450-50-00 SPROCKET, DRIVEN (50T) STD 1
15 5GS-25448-50-00 SPROCKET, DRIVEN (48T) AP 1
15 5GS-25452-50-00 SPROCKET, DRIVEN (52T) AP 1
16 90109-081G1-00 BOLT 6
17 90185-08169-00 NUT, SELF-LOCKING 6
18 90201-08326-00 WASHER, PLATE 6
19 5ET-25383-00-00 COLLAR, WHEEL 2
20 5ET-25388-00-00 PULLER, CHAIN 1 1
21 5ET-25389-00-00 PULLER, CHAIN 2 1
22 90101-08777-00 BOLT 2
23 90179-08299-00 NUT 2
24 5ET-25381-00-00 AXLE, WHEEL 1
25 90185-20168-00 NUT, SELF-LOCKING 1
26 90201-203U1-00 WASHER, PLATE 1
27 9Y581-76113-00 CHAIN (DID 520VM-114LL) 1
28 94681-76001-00 JOINT, CHAIN 1
29 5ET-25367-00-00 COVER, HUB DUST 2
2006 rear wheel
3 93306-27212-00 BEARING 1
5 93106-30001-00 OIL SEAL 1
8 94421-18008-00 RIM (2.15-18) 1
10 94111-18012-00 TIRE (110/100-18 64M D756) DUNLOP 1
11 94212-18188-00 TUBE (110-140/80-100-18 M/C) DUNLOP 1
12 94309-18146-00 BAND, RIM (2.15-18) DUNLOP 1
15 5GS-25448-50-00 SPROCKET, DRIVEN (48T) 1
15 5TJ-25450-80-00 SPROCKET, DRIVEN (50T) 1
15 5TJ-25452-80-00 SPROCKET, DRIVEN (52T) 1
16 90109-08078-00 BOLT 6
17 90185-08008-00 NUT, SELF-LOCKING 6
18 90201-08048-00 WASHER, PLATE 6
19 5TJ-2530S-80-00 COLLAR ASSY 2
20 1C3-25388-50-00 PULLER, CHAIN 1 1
21 1C3-25389-00-00 PULLER, CHAIN 2 1
22 90101-08006-00 BOLT 2
23 90179-08656-00 NUT 2
24 1C3-25381-10-00 AXLE, WHEEL 1
25 90185-20002-00 NUT, SELF-LOCKING 1
26 90201-20020-00 WASHER, PLATE 1
27 9Y58A-76113-00 CHAIN (DID 520VM-114LL) 1
28 94681-76021-00 .JOINT, CHAIN 1
frostbite
these are the part numbers for both models and they seem to match
http://www.yamaha-mo...parts/home.aspx
this is where i checked.
  • Frostbite
Posted April 19, 2006 - 04:39 AM
Thanks BB :thumbsup:
Frosty
