Cant find rear shock rebound adjuster!!!
5 replies to this topic
  • xdirtbikerx
Posted April 18, 2006 - 10:10 AM
I looked all over the bottom of the shock, (like on my yz) but didnt see any adjuster, i checked the service manuel but it didnt mention it either. is there any rebound adjustment on the rear shock? its a 2000 xr650r. would appriciate any help, the rear feels like a pogo stick over most high speed choppy stuff. thanks.
  • qadsan
Posted April 18, 2006 - 10:35 AM
The rebound screw is on the shock rod/fork that's connects to your linkage. It 'should' be on the same side as your resevoir for easier access, but it could have easily been turned around by somebody when they removed the shock to change the spring, etc. If it's not there, then you don't have a stock XR650R shock in your bike. I'm positive the rebound screw is pictured and identified in the service manual under the rear wheel suspension section and will dig out a page number if necessary.
  • xdirtbikerx
Posted April 18, 2006 - 12:45 PM
I will double check there soon as i get home from work, I suppose i could have "missed" it when i was looking, and i really REALLY hope its there. it is bone stock exsept for a baja designs light kit and uncorked. thanks. mike.
  • qadsan
Posted April 18, 2006 - 01:59 PM
It's shown on a couple different pages, but it's specifically called out on page 15-22 (3rd picture down). Page 15-17 has the best breakdown picture and the damper rod clearly shows the rebound adjuster screw on it, but it's not called out in that diagram.
  • Koko Azuela
Posted April 18, 2006 - 03:41 PM
And it's only going to get a little better with some clicker adjustments, if you want to go really fast on the choppy stuff on a 650R you will need to revalve, and if you are looking for a high speed adjuster, the 650 shock doesn't have it, if you have a few bucks to spare (more like 1000) you could upgrade the rear with a CR500 shock like the Honda guys do, Precision Concepts and other shops do this, the CR shock has the high speed adjustments just like your blue bike :thumbsup:
  • xdirtbikerx
Posted April 19, 2006 - 01:26 PM
Took my bike out last night up to Cleveland nat forest behind my house, before going, i looked where you said, i feel pretty stupid now but there it was. pretty small, compared to my yz, but there none the less, awesome!, i gave it a couple of clicks and it is noticeably better, maybe a couple more clicks next time and i will start dialing it to my liking, thanks again. mike.
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
Honda XR650L 2016
  • 0 reviews
