AMSOIL oil filters
8 replies to this topic
  • storm 800
Posted April 14, 2006 - 07:51 PM
I just got a new oil filter for my WR400 from AMS-OIL same size as stock for 7.95 They look a bit different but same size. Has anyone try ed one yet? They are about half the price as the stock ones an look about the same.
  • clark4131
Posted April 14, 2006 - 07:58 PM
What's the Amsoil p/n on that, is it SMF113? I've got an account with them, but I didn't realize they sold filters...SC
  • simon@vic
Posted April 15, 2006 - 12:22 AM
why not use the stock Yamaha SS one? they are reuasable.................
i have a SS wr426 filter to replace the paper wr450 filter in my bike.
  • storm 800
Posted April 15, 2006 - 02:15 AM
Yes it is SMF113 They just added it also they added the air filter. I don't like the idea of reusing the filter. Even the one from AMS-OIL is metal an looks to be the same if not better than stock. It seems to have a metal baffle in it.
  • simon@vic
Posted April 15, 2006 - 07:28 AM
why wont you resuse them?>
  • dl19
Posted April 15, 2006 - 02:57 PM
I know a lot of peopl use SS re-useable filters with no problem. I just have a hard time using them when they allow particle flow at or more then 5 times the better paper filters. Yes in the long run the SS will be cheaper, but I just want the best filter possible. I have used a few stock, and I am currently using the K&N. As long as the filter fits correctly, and has a tight fit from font to back it should be fine. Any slop might allow oil around the ends and then it completely skips being filtered.
  • simon@vic
Posted April 15, 2006 - 06:16 PM
the filter doesn't "clean" the oil. changing it does!!!
use a SS filter and save your $$$$ for more frequent oil changes.
i believe that will do more good then what a paper filter will stop.
  • storm 800
Posted April 17, 2006 - 02:27 AM
I haven't used a paper filter yet! For my WR All I ever seen is the stock metal ones. I guess a good filter keeps the particulate mater down.
  • storm 800
Posted April 17, 2006 - 10:11 AM
Just try ed the filter on my 400 an it don't fit. I called AMS-OIL tech an let them know about it seems there filter is about 30 Thousands too wide. but they are going to change that.
