Aluminum Throttle Tubes
5 replies to this topic
  • DrThumper
Posted April 14, 2006 - 01:48 PM
Hey guys, I need a new throttle tube. I would like to get an aluminum one, but I use handguards. Who makes a good aluminum throttle tube with an open end (or an aluminum throttle tube with a closed end that you know I can cut-off w/o messing up the tube and/or bearing...if it has one).
BTW-Its for my '00 426, if it matters... :thumbsup:
  • crfdaddy
Posted April 14, 2006 - 02:10 PM
i believe pro taper makes a open end throttle tube with a bearing in it. i have a pro taper with the bearings in it but it is a closed end. i am very happy with mine as i plan on pulling it off along with some other after market stuff i put on the 04 450 and sell it, probably going to a 250f
  • Ga426owner
Posted April 14, 2006 - 05:28 PM
If you are going to cut the ends for handguards buy the cheapest one you can find sunstar..... :thumbsup: Do not get one with the bearings unless you give up the handguards or just use roost protectors
  • ridesblue
Posted April 15, 2006 - 04:20 PM
i got one from performance engineering and it has an end that you can punch out for hand guards
  • DrThumper
Posted April 17, 2006 - 01:06 PM
Thanks Guys!
  • gjones
Posted April 18, 2006 - 04:26 AM
Moose Racing makes an open ended aluminum throttle tube.
You will have to order through Parts Unlimited.
  • 0 replies
  • Hot  36 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 5 replies
