Seat Cover Install
No replies to this topic
  • prwler
Posted 14 April 2006 - 07:11 AM
Here's what you need.
1. Small flat blade screwdriver
2. Needle nose pliers
3. Staple gun and staples 1/4 or 3/8 will work
**Buy or rent an electric stapler**
3. Hair dryer
**Not required but it helps**
Attached Image: TTpictures096.jpg
Clean you seat, just don't get it too wet (foam will swell)
Attached Image: TTpictures098.jpg
Check fit to make sure you have the right cover before taking off the old one!
Attached Image: TTpictures097.jpg
Remove staples
Attached Image: TTpictures099.jpgAttached Image: TTpictures100.jpg
Check your foam for damage, repair with contact cement
Attached Image: TTpictures101.jpg
Start with the top (tank) area of seat, put in a couple of staples
Attached Image: TTpictures102.jpg
Work your way down the sides pulling tight and stapling, if you have a few wrinkles, remove the staples in that area and smooth out. This is where a hair dry comes in handy. Warm up the seat cover, stretch it into place, and staple it. As it cools, the material will shrink making for a nice tight fit.
***be careful not to heat it up so much you melt the plastic***
Attached Image: TTpictures103.jpg
When you get most of the way done put the seat on the bike and check fit, the tank may pull or push the seat and cause a wrinkle
Attached Image: TTpictures109.jpg
Hear again, remove a few staples and stretch and re-staple
When you done you should not be able to pinch up the cover
Attached Image: TTpictures111.jpg
Install seat, it should look smooth and tight
Attached Image: TTpictures110.jpg
Now go Ride !
