650l fork Q's
2 replies to this topic
  • 1150santa
Posted April 13, 2006 - 11:32 AM
I have a 96 650 L fork and want to change the oil.
What is the stock oil level for these forks?
Is this measured at full compression?
Is this with the spring out or in the fork leg?
Anything to watch out for?
Thanks.
  • Boy named sue
Posted April 15, 2006 - 04:14 PM
It's 146mm at full compression with the spring out I went 148mm with 10w but I'm 225lbs. hope this helps
  • underwatersimon
Posted April 15, 2006 - 06:30 PM
The recomended volume is 564ml - this was a little shy of the mm measurement so I added 2 more - It was much easier to measure the volume first, this enables you to keep both forks the same.
make sure to bleed before reinserting the top. Just put it through a few strokes...SLOWLY! or you'll overflow.
  • Hot  28 replies
Honda XR650L 2016
  • 0 reviews
  • 8 replies
  • 17 replies
  • 22 replies
