Removing indicator/headlight switch?
3 replies to this topic
  • flatnacker
Posted April 11, 2006 - 05:19 PM
Hey guys, I want to remove the indicator/headlight switch from my bars but retain use of my headlight. Anyone done this? There is by memory 3 wires that run from the switch to the headlight but only two that run from the battery loom (I think) If I just diconect the three wires from the switch should the headlight still work?
  • flatnacker
Posted April 11, 2006 - 10:15 PM
Bumpety
  • flatnacker
Posted April 12, 2006 - 03:03 PM
Bump, surely someone has taken the switch off the left hand side of the bars??
  • Gadsen
Posted April 12, 2006 - 03:21 PM
I added a switch and I suspect its one wire in (AC power) and onre out to the headlamp, the other out to the tail lamp. So I suepct you just connect all 3 together and you will have lights/tail lamp on always.
