What's that noise?
6 replies to this topic
  • Kinsman
Posted April 10, 2006 - 08:46 AM
93 650 L; 17,000 happy miles.
Sounds kinda like chain slapping but the tension is right.
Chunk-clunk-chunk mostly when I am in first or second, putt-putting.
Did not make the sound when I put it on the stand and ran it in gear.
If it's chain hitting something no big deal but if it is coming from inside, it is a scary noise.
Any ideas?
  • cleonard
Posted April 10, 2006 - 09:45 AM
Cam chain tensioner no longer doing it's job?
  • captb
Posted April 10, 2006 - 09:55 AM
Probably just the engine balancer backlash, not a problem, some make noise when new.
  • Kinsman
Posted April 10, 2006 - 11:34 AM
OK, what are consequences and is either one an easy fix for a guy who ain't real wrenchy?
  • ghoti
Posted April 10, 2006 - 12:09 PM
Any ideas?
My 04 started making noise down by the front sprocket during low rpm acceleration after a new chain, slider and sprockets. Everything is lined up and tight. I think it's because the replacement sprocket doesn't have the vibration dampners like the OEM. I guess I'll wait til it breaks, then fix it.
  • Super_dave0069
Posted May 27, 2008 - 12:09 PM
Did anyone figure out the clunking sound? I think I have it now too. I did a lot of maintenance over the winter so I can't say for sure what caused it. I changed front and rear brake pads. I also put a wave rotor on the rear. I changed the chain and both sprockets and now I have a clunking sound while putting too. I can hear it very well when I pull the cluch and just coast with no throttle. Sounds like the chain is hitting something but I can't figure out where. Tension is correct. Any thoughts?
  • XR650L_Dave
Posted May 27, 2008 - 02:07 PM
Is the slider just under the swingarm pivot missing?
Weird that you'd hear it with the clutch pulled in. Something misaligned?
Swingarm bearings wiped?
Rear wheel bearings wiped?
Just guessing...
Dave
