yz 400f top end // wr400 bottom end?
1 reply to this topic
  • rgd420
Posted April 08, 2006 - 06:01 PM
just picked up this 98 YZF400 from a friend. Had some carb trouble. I got it running was a couple of things. Stock jetting and still a little lean. It runs best with the choke on, so I may bump up the main 1 and the pilot a little more and maybe change the needle. I believe it is bored with a possible high compression piston and a cam. It runs like a raped ape on top but has a bog on bottom I need to clear up....
Anyway this thing has a yellow wire that comes out at the handlebars that puts out juice. It's plenty to power a light. I do have the stock bottom end to this bike in a milk crate and the one that is in the bike has that extra wire coming out. Is it possible this is a WR motor? Or bottom end anyway?? I don't know of any kits { ricky stator} that use the factory side cases for an add on lighting coil.
Any help would be appreciated.
Thanks
  • Butta
Posted April 09, 2006 - 10:23 AM
Thanks
I had a YZ and a WR 400, both '98's, and I ended up switching the WR motor out for another YZ ('99 motor) after the rod decided to split length-wise. I found that in order to run the WR with the YZ motor in it I had to run the WR stator (the wiring harness on the frame/cdi needed the WR setup from the stator - I tried it with the YZ stator with no luck, and a swap of the stator and flywheel and it started right up). So, it's quite possible you have a WR chasis with a YZ motor using a WR stator, or it's just a WR with YZ ergo's, or it's a YZ with a WR stator/flywheel/wiring. Check under the left footpeg to see if there is a spot for a kickstand, and check behind the left sideplate to see if there is a spot on the subframe to mount the coolant reservoir that comes on WR's. If neither spot shows signs of WR, then chances are you have a YZ bike with a WR electrics.
Clear as mud?
  • On January 15, 2017
  • Hot  50 replies
  • 0 replies
  • Hot  28 replies
