What happens when your in a hurry
10 replies to this topic
  • 25year2stroker
Posted April 08, 2006 - 04:44 PM
Loaded up to go for a quick 1 day ride tomorrow,In my haste I forgot a couple of things. One very important thing was my battery left on the trickle charger which is now 250 mi away.No name calling please as
i called myself every one in the book the last 100 mi. Question for the community,will the bike run with no battery? I have not tried anything yet cause I'm still pissed.Any help would greatly appreciated.05 wr450
TIA
  • dl19
Posted April 08, 2006 - 09:05 PM
Yes it will run fine.
  • Bamster
Posted April 08, 2006 - 09:37 PM
Just kick it.
  • new2blu
Posted April 09, 2006 - 06:47 PM
Buy either a battery tender that comes with a special jumper that is always connected to the battery and it can be charged with the battery in the bike. Or make/purchase a jumper to hookup to your trickle chrger;then that will never happen again. I just stuff the jumper into the right side "handle hole" in the side cover.
  • PBDBLUE
Posted April 09, 2006 - 07:16 PM
Make sure you tape up the battery connections. If the positive lead shorts to the frame or the - lead you will most likely blow the regulator.
  • kskyles
Posted April 10, 2006 - 09:33 AM
this is what i did.
i think new2blu did the same. it works out really well. you never have to mess with taking out the battery.
http://i41.photobuck...BattTender2.jpg
http://i41.photobuck...BattTender1.jpg
  • sauve-yfz450
Posted April 10, 2006 - 10:06 AM
this is what i did.
Dude thats a nice set up good job :thumbsup: :thumbsup:
  • PBDBLUE
Posted April 10, 2006 - 10:21 AM
I did the same except I extended the connector up behind the headlight so when you don't have the charger plugged into you can connect a GPS (or any other 12V accessory) to it if you like.
this is what i did.
  • GCannon
Posted April 13, 2006 - 09:25 AM
Put the seat on the work bench next to the battery. You will probably never load your motorcycle in the truck without a seat
  • new2blu
Posted April 13, 2006 - 06:24 PM
this is what i did.
Yes I did the same thing only I don't have a "handle hole" on the left;so my plug exits on the right side.
  • new2blu
Posted April 13, 2006 - 06:27 PM
That is a good idea also. I like leaving whatever I need to take with me in front of the door so I trip over it on the way out---that way it dosen't get forgotten.
