New WR426
7 replies to this topic
  • H20Pumper
Posted October 10, 2001 - 12:14 PM
Have been reading TT for a couple of months, trying to decide on a bike. 426/xr400. Just ordered 2002 WR for X-mas present! I need protection skid plate, radiator guard and hand guards. I saw the pictures DL posted and saw his stuff. Any comments, suggestions. I have been out of touch for the last 15 years and am looking for help.
  • tripm
Posted October 10, 2001 - 12:38 PM
Just one suggestion. Don't buy a carbon fiber skid plate. Only my .02.
  • tbronco
Posted October 11, 2001 - 05:57 AM
Welcome! I don't think you'll be disapointed.
The guards are a very good idea.
Otherwise I'd suggest riding it as-is the first few times. Then you'll want to trim the throttle stop, take the lid off of the airbox, and pull the end plug from the exhaust. Replace it with one of the replacement ends available, to calm the noise, if you can.
I'm not sure if the "grey wire" will make a difference on the 426 or not. Get some riding time on it first, then decide if you want to cut it. That's also the time to consider going to YZ timing.
If you search on any of those mods you'll find lots of info. Just ask the group if there are more questions. Great and knowledgeable people here.
tbronco
98 WR400 Dualsport!
  • mcarp
Posted October 11, 2001 - 07:07 AM
Oil and grease the airfilter....it's dry when new. Check spokes and all bolts. Grease the bearings. Give the machine a good inspection before you roost.
Lastly, break in the machine gently and give several oil changes the first hundred or so miles.
Handguards are probably the most important guard. Radiator guards are a good idea, get either Devol or Thumper, not works connection. Then spend money on carb jets and needles in preparation for YZ timing and removing all the restrictors.
For me, jetting was a concern. Stock the bike simply did not run all that strong...IMHO. Jetting needed many adjustments to bring the fire alive.
So try not to be disappointed with the stock setup, there's many HP to be uncovered.
  • Tom14911
Posted October 12, 2001 - 06:32 PM
Barkbusters, Answer bars, W.E.R. skid plate, works connection frame guards, Devol radiator guards and Devol rear disc guard. Works connection rear caliper guard. That ought to get you started. ME? 2001 WR426. All mods including grey wire
  • Ron_S
Posted October 13, 2001 - 01:13 AM
The guards are a must along with the air box lid and throttle stop. You should ride for a while before you go think about the YZ timing. I was out of riding for about 17 years, and the testosterone level loss that comes with age doesn't require any more performance out of my 99 WR. Getting back into riding after such a long layoff is the best thing I could have done. Enjoy!
  • William
Posted October 13, 2001 - 09:07 PM
Tripm, why not a carbon fiber skidplate
2002 KTM 400 exc
2000 WR400F
2000 EC 300
2000 TTR 125L
2000 TTR 90
1999 750 Katana
# 1
  • TeamScream
Posted October 14, 2001 - 04:48 AM
HAve you seen a carbon fiber skid plate after a few rides ? they tend to splinter and get really ragged looking fairly fast, remember carbon fiber is basically glorified fiberglass.....nothing more......plus its expensive....has its places however....just not in an area that gets a fair amount of slag thrown at it on a regular basis
01' WR426,YZ timing,EMP #2,#48Pilot,#100PAJ,#175 Main,BK mod,Kouba T-Handle,YZ pipe, open airbox,Gray-Wire Pulled,K&N Filter, throttle stop mod,CA Street Legal,Pure SuperMotard 17 in. wheels,Braking 320mm "wavy" front rotor, 15/46 gears,ProTaper bars,
