2006 450 3rd gear jump
4 replies to this topic
  • speedster
Posted April 06, 2006 - 07:14 PM
hey guys when ihit the double step up with the 2004 450 no problem clearing but with 2006 450 i cant quite clear it. the transmission ratios show same for 2004 and 2006. the jump is about 65 feet. anyone else run into this? thanks larry
  • CROGGR
Posted April 06, 2006 - 10:55 PM
The ratios may be the same but the final drive and primary drive gears are not. 3rd gear on the 06 is slightly lower. You may have to drop a tooth on the rear sprocket to compensate!
  • Lizard 1
Posted April 07, 2006 - 03:52 AM
Uh, you realize the 2006 has a 5-spd, right? The final drive ratios will be different. Plus, internally, I can't believe the ratios are the same...
  • MotoGoalie
Posted April 07, 2006 - 06:54 AM
Is that out at Watkins?
  • speedster
Posted April 07, 2006 - 10:17 AM
no erie
  • 0 reviews
  • 9 replies
  • Hot  47 replies
