Scotts Oil Filter Cleaning
10 replies to this topic
  • Unkle_Moose
Posted October 09, 2001 - 07:04 PM
Just wondering how everyone is cleaning their stainless steel filters, is their a better way then hot water and dish soap.
Ride Often & Ride Safe
  • Tennessee_Thumper
Posted October 09, 2001 - 10:31 PM
I've had good luck with contact cleaner.
  • MX_Tuner
Posted October 10, 2001 - 01:20 PM
Same way you clean the stock filter. I use aerosol brake cleaner. I'm still on my original '98 filter.
MX Tuner
  • Ga426owner
Posted October 10, 2001 - 03:15 PM
Mark, aerosol brake cleaner on a air filter?
Interesting, I have not tried this. Kerosene has worked for me with the same longivity results.
On the Scotts, I use Contact or Brake cleaner & wash out with hot H2O.
  • MX_Tuner
Posted October 11, 2001 - 01:35 PM
Oil filters, Dave. I *have* used brake cleaner on an air filter in a pinch, but I'm leery of what it'll do to the foam after time.
MX Tuner
  • Unkle_Moose
Posted October 16, 2001 - 06:38 PM
Thanks for the input guys.
  • BlueThunder
Posted October 16, 2001 - 06:53 PM
Uncle Moose....did that thing really cost $70? Tell me the filter changes your oil for you too? Wowee they're really proud of those.
Y2K WR400FM,Answer top tree w/Accu-Trax clamp,Pro-Tapers(CR-Hi w/ EE handguards),Devol Rad. & frame guards, Guts tall soft foam w/ ballistic cover, 14/52 w/DID VM X-Ring, Kouba-T,Michelin M-12's ft.& rr.,12 oz. flywheel weight, Zip-Ty Racing Link & Shark Fin(plus everythhing else cool that Ty offers), Cycra front rotor guard and T.M. Designworks Chain guide, buffer & chain wheels. Street legal except for the non-"DOT" tires.
  • Unkle_Moose
Posted October 16, 2001 - 07:05 PM
Yes BlueThunder it cost $70 but I don't have to replace it. Paper filters I used to replace every oil change, this will save me money in the long run.
  • MX_Tuner
Posted October 17, 2001 - 02:27 PM
Uncle Moose, I'm still on my original '98 oil filter. You don't need to replace the stock filter.
MX Tuner
  • MS
Posted October 17, 2001 - 02:46 PM
Unkle Moosey: I too clean my stock filter with contact cleaner, brake cleaner, then give it a good drying out with low pressure air from the inside. Im still using my stock filter with my 98 as well. no rips or tears so far...
  • Unkle_Moose
Posted October 17, 2001 - 06:53 PM
Hey you guys that are still using your stock paper oil filter Posted Image ARE NUTS Posted Image I could never take that chance with an oil filter. Every other ride or 100 miles change oil and clean filter. Might not do much else to the bike, but oil & filter yes.
