Seeking advice/help with rear wheel for the sand
5 replies to this topic
  • ibAdam
Posted 05 April 2006 - 12:37 PM
I currently own a 00 DRZ400E and will be doing some trips to Sand Mountain with it. I'm trying to get a complete rear wheel set up with a paddle tire on it so I can do a quick swap. So far my options I've seen for hubs are Z hubs, Rad hubs and Talon hubs. A Talon hub set up is $100 more than the Z hub and Rad hubs are somewhat in the middle. Does anyone have any reasons I shouldn't go with the cheaper Z hub?
Second question. I'm planning on buying a WR450 in a few months. Will this rear wheel set for the DRZ fit the WR (or a TT-R 250 which is my second bike)?
  • ibAdam
Posted 06 April 2006 - 09:28 AM
Anybody have any input???
  • ROUNDEYEHELMETHEAD
Posted 06 April 2006 - 09:59 AM
z hubs, meaning oe hubs? if so, i'd sat there's nothing wrong w/oe hubs.
as far as interchanging between a wr or a tt-r, i highly doubt it. but i could be wrong.
  • ibAdam
Posted 06 April 2006 - 01:29 PM
No I found an actual manufacture that makes 'Z hubs' which is not related to a specific bike like the DRZ or it's OEM parts. It's just another aftermarket part. I'm just baffled that a complete rear wheel is $500. I still have to get the tube, bead lock and tire which will probably be another $100. I'm trying to locate a used one, but so far no luck.
  • HalfNutz
Posted 06 April 2006 - 02:51 PM
Get the Talon with the interchangeable carrier. That way you can use it with the WR by just getting a WR carrier.
  • toon69
Posted 07 April 2006 - 02:36 PM
I tried the paddle tire on my 01 DRZ400E, and I had to gear way down 13/47. Also, when I jumped the tire hit the fender before bottoming out.
Now, I run a MX tire in the sand with 15psi and it works well plus I can ride hard pack. The drz has enough weight to use a nobbie. :ride:
Glad to hear theres another DRZ sand lover :applause:
Shane
