I have not yet completed the suggested Primary Nut fix. I have just purchased required gaskets and I believe I almost have all the info I need.....almost. I know that the nut on the ignition side is a 26mm and requires either a deep socket or an offset wrench, what size is the primary nut itself, and can you complete the fix (Loosen, Locktite, and Tighten) without removing the clutch basket? :thumbsup: It also sounds like this would be a good time to dig into the starter gear bolts to make sure they are tight as well?
Primary Nut size ????
Started by obrianmcc, Apr 05 2006 11:57 AM
8 replies to this topic
Posted 05 April 2006 - 11:57 AM
Posted 05 April 2006 - 01:24 PM
Yes check the starter gear bolts, and the P/Nut is 27mm.
You may need two 27mm sockets, as my 26 mm socket would not fit the rotor nut.
Neil. :thumbsup: :ride: :ride:
Posted 05 April 2006 - 02:58 PM
Posted 05 April 2006 - 03:37 PM
obrianmcc said:
Thanks for the tip...can you tell me if it is necessary to remove the clutch basket?
In fact I checked the P/N the rotor nut and starter gear bolts as well and they were all below the specified torque as was the P/N and clutch centre nut.
Posted 05 April 2006 - 04:43 PM
I have a 2003 400E and the primary nut wa loose . Needed 27mm for both sides as stated above. You need a left hand tourque wrench.(left hand thread)
Posted 05 April 2006 - 05:05 PM
I have 3 reversible torque wrenches, and none of them worked in reverse.
I ended up using an old flexy beam type, that has been gathering dust for the last 30 years.
Posted 05 April 2006 - 06:13 PM
obrianmcc said:
OK...Tell me if I'm on the right track...I've been studying the diagrams on Ron Ayers...
1) You have to remove the "Stator Assembly" and the "Magneto Rotor" in order to access the "Starter Clutch Set" to check the torque of the starter clutch bolts?
Sound right?
Sound right?
Remove the generator cover, and the starter gear bolts are visable.
I removed them one at a time, degreased the thread and the bolt, and loctite'd them in place.
