Big boy suspension setup
5 replies to this topic
  • Old_Yeller
Posted April 05, 2006 - 07:37 AM
What are you big guys (275+) running on your suspension?
I was going to get a Race Tech 6.4kg for the rear but it seems like there is no front spring close to what they calculate I need. I guess I would just get the heaviest spring they make.
Do I have to revalve too?
Should I change the weight of oil in the front shock?
The rear spring seams fairly easy to change, how hard are the front springs to change?
I just bought a house so I'm strapped for cash. What changes would give me the most bang for the buck?
Thanks in advance!
  • Captain Bob
Posted April 05, 2006 - 08:44 AM
I am another big guy weighing in at 250 -260. I have a 6.4 rear spring and .48 springs in the forks. My bike was set up for MX so I also had to revalve forks and shock. This made a serious difference! I am now able to set sag properly and the "hit" on sharp bumps is much softer. Before making these changes the bike was difficult. I would get serious arm pump and was not able to keep up with folks because I was bouncing all over the place.
You definitely need new springs. I do not know however, if revalving is required. It really depends on how the suspension was set up before you got the bike.
Hope this helps.
  • longie
Posted April 05, 2006 - 11:03 AM
Call Too-Tech suspension in Torrance,Ca. He can get very heavy springs and has worked with BIG riders....310 378 3771
  • JDrooster
Posted April 05, 2006 - 12:03 PM
Matt at Active ride can get you springs. He's a great guy, and can revalve for you as well. -Jerry
  • bg10459
Posted April 05, 2006 - 04:54 PM
I'm 6-5, 270 and I have a racetech 6.4 in the rear, but they didn't have anything stiffer than a .48 for the forks. I wound up getting .50 fork springs from MX-Tech for less than Racetech wanted.
I thought MX-Tech advertised on TT because that's how I found them, but I can't find them now :thumbsup:.
  • black_n_blue_thumper
Posted April 05, 2006 - 11:04 PM
Look up Cannon springs under sponsors right here on TT. My buddy got his front springs(.52) from them and got a Race Tech 6.4 rear and had a Race Tech dealer do gold valves and full front and rear setup. Very nice stuff.
