More Battery ?s
17 replies to this topic
  • rockchucker22
Posted 05 April 2006 - 05:43 AM
Has anyone tried these batteries? http://shop.thumpert...tCode=TR_499095 I'm in the market for a new one and e-mail TT store and Brian Bosch recommended this one, its more than 50% cheaper than the yusa and I will most likely get this one , i just wanted to check with everyone first. :ride:
  • JoeDints
Posted 05 April 2006 - 05:52 AM
I just put a Bike Master battery in my DRZS 3 weeks ago, got it at my local shop. $52.00... Charged right up and been fine so far....
  • ROUNDEYEHELMETHEAD
Posted 05 April 2006 - 07:02 AM
i have one in my e/sm as recommended by brian also. charged it up when i got it & have had no problems so far.
  • Noble
Posted 05 April 2006 - 08:15 AM
My experience with cheap bateries is they are cheap batteries. They are lighter, less plates, fewer CCA. In most cases they work just fine. However, in the case of DRZ400, the OEM battery is marginal to start with so to reduce CCA any more is asking for problems. If you are happy with a half price battery, that's fine. I was not. It was not from TT but they are probably all made the same place.
  • JoeDints
Posted 05 April 2006 - 09:19 AM
I got 4 years out of my stock battery... if this battery lasts 2 years at half the price, looks even to me.... anything more, the better..
  • rockchucker22
Posted 05 April 2006 - 11:21 AM
Your the drz electrical expert so I highly value your opinion on the subject, what kind did you run? My battery lasted 4 years and then after my last ride it went dead... I'm thinking I hit my gps switch that has a small led light that drained it over the last couple of weeks, do you think it would be enough to completely kill my battery??
Thanks everyone for the input! :thumbsup:
  • tom slick
Posted 05 April 2006 - 06:01 PM
I've had that exact battery in my bike for about a year. It's plugged into a battery tender when I am not riding. I have had zero issues with it.
  • krac
Posted 05 April 2006 - 07:36 PM
Just got the same battery from my local dealer. Seems like an ok battery.
If I get stuck out in the boonies. I will let you know!
  • Noble
Posted 06 April 2006 - 03:33 PM
rockchucker22 - The cheap battery I used was from Chaparral, Lynn Vick Products (LVP) It just never had any poop to it. I used it for a month. Maybe it was just a poor example but I returned it and put the 5 year old GS back into service. That lasted another 10 months and I finally put in a Yuasa. The difference in starting between the old GS and the new LVP was nada. It was cross your fingers. (E bike with S compression but no auto compression release). The difference with the new Yuasa was a big difference. Hit the button and boom its running. I need all the CCA I can get.
  • rockchucker22
Posted 06 April 2006 - 03:53 PM
The yusa I had for the last 4 years fired my E up with ease its entire life, you have me leaning towards old tried and true yusa.Although everyone that has had personal experience with this particular battery seem to like it :excuseme: I have a few other things I going to order so I have a week or so to decide! :thumbsup: Thanks for all the comments...keep them coming! :applause:
  • OCKBOB
Posted 07 April 2006 - 06:45 AM
I just installed one I got from Rocky Mountain ATV which cost me about $45 delivered. I road last weekend, and it fired up the bike nicely. I was trail riding with some ATV's and stopped the bike often with no problems firing back up. Bike seemed to run better with the new battery also.
  • Rotor388th
Posted 07 April 2006 - 10:44 AM
My battery went dead over the winter. Completely dead nothing wouldn’t even make the smallest bulb I could find glow the slightest. Charging did nothing. Trickle or Boost. Popped the top off of it (factory battery) had a bit of trouble but still came off without damaging anything. Looked at for awhile… :prof: figured what the hell add some water can’t screw it up any more than it is. So I added 3mls, of distilled water, charged it for 1hr on 2amp charge. To my surprise it came back to life slightly. So I added 3 more & then a nother 3mls more of water charged up for another 1.5hrs. whamo the battery is back in my bike. Been running it for 2 weeks every day. Granted its probably not going to last real long time. But dam it’s cranking the bike over real nice. I’m not going to rush out to buy a new battery as is :ride:
  • rockchucker22
Posted 07 April 2006 - 02:52 PM
Welcom to TT! That sounds like my battery, maybe I will try that this weekend! :thumbsup:
  • Rotor388th
Posted 08 April 2006 - 09:46 PM
Put it to the real test yesterday.. ran good all day except when I forgot the key on for about 10min. then I had to pushstart it. :crazy:
  • playshark1
Posted 15 April 2006 - 09:29 AM
was that 6ml of water per reservoir or was that 6ml total. And does it have to be distilled water.
  • shift1313
Posted 23 April 2006 - 12:50 PM
I had a dead battery also after 4 years and just for kicks i added some distilled water then threw it on my battery tender. it leaked. I thought well maybe i just put too much water in and it was just venting so i popped the top, resealed it and charged it again overnight on the battery tender and there was a big spot on my garage floor. The battery came back to life but every time i charged it, it would vent acid so i decided to chuck it and when i pulled it out, the battery acid ate around the positive terminal and reeked havok. I dont reccomend ever refilling a sealed maintinance free battery but I had to find out on my own. If you do decided to do this just be ready to etch your garage floor or worse case, your swingarm if you charge it in the bike.
  • rockchucker22
Posted 23 April 2006 - 04:14 PM
Yikes... I decided just to get a new one.....as Noble pointed out we need all cca's possible!
  • vanram
Posted 24 April 2006 - 10:58 AM
How much water did you use, you need only a small amount of water to moisten the fiberglass mat inside the battery. Start off with a couple ml per cell. Rotor388 used more water than I did to bring his back. Your battery case must be cracked and in that case get a new battery. Hope this doesn't discourage anyone else from trying it, my battery is still going strong almost a year to date from when it started acting up. No tender, wiring fix, 14.4v on bike.Still have new battery in the box :applause: :applause: vanram
