Coolant Overflow
9 replies to this topic
  • Lok47
Posted April 04, 2006 - 11:09 PM
This past sunday at the Firebird Raceway, my 2000 WR400 was filling up the coolant resevoir. Is this a sign of overheating? Blown head gasket? The temperatures weren't that high. It was probably 85 air temp and maybe 100*F track temperature. The track is a 11 turn 1.25 mile road course, so it had adequate air flow to radiators.
  • Matty05
Posted April 04, 2006 - 11:39 PM
This is what it is there for!!!!!
I bet you when it got cool, the level dropped again.
  • pkcof
Posted April 04, 2006 - 11:49 PM
The first thing that i would check is the radiator cap - 6 years old and after all it's only a cheap spring and a piece of rubber (subjected to heat and pressure) - tap washers don't last that long.
Secondly, check the plug to see if it's perhaps running a little lean - this can cause it to run a little hotter than normal ...
good luck ...
  • Lok47
Posted April 06, 2006 - 02:24 PM
what would I check on the radiator cap? What effect does it have on cooling?
  • STEEL CITY ROCKER
Posted April 06, 2006 - 02:32 PM
The rad cap pressureizes the coolant system, raising the coolant/water's boiling point. A weak rad cap would lower the boiling point send the boiling coolant into your res.
  • GCannon
Posted April 06, 2006 - 03:42 PM
You are testing the radiator cap's ability to hold pressure. Or hold coolant in the cooling system if your radiator cap is more than a year old replace it. You can also search and order a 20 pound cap stock is 16 pound I belive after all this then start looking for a cooling problem.
  • Lok47
Posted April 06, 2006 - 03:47 PM
Okay, the level has not dropped in the resvoir. Does that mean anything to you guys?
I'll definitely pick up a new radiator cap. Should I pick one up directly from a dealership or is there a recommended after market one?
  • Lok47
Posted April 07, 2006 - 01:31 PM
What if the coolant doesn't get sucked back into the radiators, from teh resevoir?
  • Matty05
Posted April 08, 2006 - 08:57 PM
Take off the radiator cap and see if the collant is covering the fins. If it is, don't worry. It should not be totally 100% full, there will be an air gap of maybe 1/2" - 2/3".
  • Chas_M
Posted April 08, 2006 - 10:42 PM
Most coolant recovery systems will not 'recover' the coolant properly unless the rad reservoir is full to the top due to the discontinuity of the vacuum column.
