Maybe someone might have an idea. I have a 2002 DRZ400S with motard tires, This morning I was cruising to work on the freeway when all of a sudden the engine felt like it wanted to cut out. It didnt die and I barly made it to work it kept popping out of the exhaust. Almost sounded like there was water in the gas. well I drained the tank and the float blowl. refilled and rechecked: samething. So I got it home. went to crank it and it sounded like there was no compression. Then all of a sudden it had compression and made a god awfull noise. Now I cant get the dam thing to start. I checked my valve clearence checked the valve timing they are spot on. As it was cranking it was popping out the exhaust but would not fire. Anyone have idea ideas on where I should go? before i pull the head off??
thanks
