fitting full yosh TRC on a SM?
18 replies to this topic
  • Bamboo
Posted 04 April 2006 - 06:20 PM
ok so i've read that some people have problems fitting them on the s and sms?
I know its for an E But whats so diffrent the mid mount?
If so, what will i have to do exactly to make it fit? Im still waiting on my jet kit and filter so i have some time to figuer it out :-p
So does it fit? or not, if not, do i just have to make an extended bracket? oh, btw its going on an 06 400sm
thanks guys.
-patch
  • Eddie Sisneros
Posted 04 April 2006 - 06:28 PM
they fit.you use the lower passenger foot peg bracket bolt for the mid pipe mount.drill the threads and use a longer bolt.
you use the hole behind the stock muffler mount to mount the yosh clamp.
  • Bamboo
Posted 04 April 2006 - 06:38 PM
ok cool, Thanks bro, ill let you all know how it goes ;) its going to be a whole new bike!
-patch
  • HotCorner
Posted 04 April 2006 - 07:15 PM
"frill" = drill in burnedspeak
My main problems were (1) clearance between bottom of left radiator and the headpipe and (2) the spring rubbing the pipe. The first problem was solved with a couple of light taps on the bottom of the rad with a hammer. The second was addressed by grinding the backside of the subframe tab in order to move the pipe out away from the spring.
  • Bamboo
Posted 04 April 2006 - 07:35 PM
you have any pictures bychance?
-patch
  • dhbiker517
Posted 04 April 2006 - 08:34 PM
is there something wrong if my TRS fit perfectly to all the stock mounting places?
  • Gyro
Posted 04 April 2006 - 08:44 PM
Its because you haven't beat on your drz as much as others. Things chance position when you crash hard.
  • Bamboo
Posted 04 April 2006 - 09:16 PM
Also the TRC is diffrent then the TRS no?
considerig my bike is brand new.. will i not have a problem? haha..
-patch
  • dhbiker517
Posted 04 April 2006 - 10:01 PM
my bike has had its fair share of hell...
  • Bamboo
Posted 04 April 2006 - 10:11 PM
i think it might just be the TRS ? and the TRC cause its newer its diffrent? But shit what the heck do i know..
-patch
  • Eddie Sisneros
Posted 05 April 2006 - 04:37 AM
the only difference is the end cap.
  • Bamboo
Posted 05 April 2006 - 07:53 PM
well maybe mine will fit fine :D
and hey, in the FMF Powerup jet kit, theres every thing i need to rejet for pipe/3x3/k&nfilter right?
-patch
  • Bamboo
Posted 10 April 2006 - 10:48 AM
after reading all about muahman's problems, can you tell me what bolt i should get? any kind?? Also the "lower" passenger peg? meaning where?
thanks ill be doin it around 1 today :D
-patch
  • MountainDog
Posted 10 April 2006 - 12:37 PM
-patch
I don't think the FMF kit includes the recommended #25 Pilot Jet
  • Bamboo
Posted 10 April 2006 - 01:42 PM
oh ? Where could i get that?
-patch
  • Motor-N
Posted 10 April 2006 - 03:22 PM
-patch
If you haven't finished yet you can see the "where" by looking at my bike(amongst others) in the garage section. I ended up with 1/4" of spacer (washers) between lower bolt of subfame and main frame,so that midpipe would clear shock spring and the engine.
  • Bamboo
Posted 10 April 2006 - 03:46 PM
Cool, Havent done it yet, that helped, made it look easier lol, What kind of bolt will i need? how long so on, do you know?
-patch
  • Motor-N
Posted 10 April 2006 - 04:01 PM
Mine ended up being aprox.15 mm long. Thickness of foot peg bracket + the makeup on the Yosh - a fuzz to keep from bottoming against the pipe itself. I think it's an 8mm dia. bolt, don't quote me, I used one from my bins, don't remember if I shortened it or not.
  • Bamboo
Posted 10 April 2006 - 04:36 PM
oh ok, Well turns out im not doing to today, going to hawaii for a week, so it'll be done when i get back >.< i wanted it done, But hey, hawaii isnt so bad, right?
-patch
