I have just recently completed the install of a MCCT. After inspection of the stock unit I can see how it can prematurely stretch the cam chain. My question is....the chain is going to stretch from normal use..how do you know that it is time to adjust? I can see this being a gradual thing and that maybe you wouldn't notice the need to readjust immediately? Is there a chance of the chain skipping a tooth when this happens or when the chain starts to loosen? Will the cam chain skip a tooth if the MCCT is in place but maybe running a little on the loose side of adjustment? Does most everyone just readjust every 6 months to a year? or does the cam chain stretch very little once the stock tensioner is removed? :thumbsup:
MCCT ...When to adjust
Started by obrianmcc, Apr 04 2006 06:15 AM
5 replies to this topic
Posted 04 April 2006 - 06:15 AM
Posted 04 April 2006 - 06:47 AM
Adjust when it starts to rattle, mine is now 7500 miles in, has not been touched, except when installing a Hot Cam about 700 miles ago, but it was not rattling when removed.
Neil. :thumbsup: :ride: :ride:
Posted 04 April 2006 - 07:41 AM
When it starts to rattle, like Neil said. Never had to adjust mine, yet.
Posted 04 April 2006 - 08:42 AM
Neil,
I'm doing the Hot Can install this week. Did you have to remove the MCCT or just back it out? :excuseme:
Thanks...
Posted 04 April 2006 - 09:25 AM
BKKoffroad said:
Neil,
Thanks...
Thanks...
Which ever is easiest for you, I removed it as that was easier, but I do not have an Oil Separator in the way.
