XR650R Exploded Oil Pump in Baja
3 replies to this topic
  • SenorGG
Posted April 03, 2006 - 10:05 PM
All:
The oil pump on my 2000 XR650R exploded in Baja. Up until then the bike seemed to be running running fine. Then I saw it wasn't getting oil to the frame reservoir after a thorough warm-up and was blowing oil out the crankcase vent into the airbox. First I checked for clogged oil lines and they were clear. So I pulled the right case half in a motel parking lot. The outer impeller (the pump that pulls from the frame reservoir and feeds the engine) looked fine. The inner impeller (the pump that pulls from the bottom of the case and pumps to the frame reservoir) was in pieces.
2 weeks ago I exploded a couple clutch discs and both filter screens and the bottom of the case had many aluminum chips. I think chips jammed the impeller and caused it to detonate. Before the trip I flushed the engine multiple times with kerosene and changed the oil 4 times.
Here is the question. Looking at the oil flow diagram in the shop manual, it shows that the paper oil filter as the last step of protection before the oil gets to the engine and the transmission. The inside of the paper filter looked clean. From the diagram it looks like I don't need to worry about aluminum chips in my engine and tranny.
I have torn down a bunch of 2 stroke motors. This is the first 4 stroke. Do I need to split the cases on this engine to make sure no aluminum got into it? Is there any other way to make sure all the passages in the engine and tranny are clear and not obstructed by aluminum chips?
Thanks!
  • cleonard
Posted April 04, 2006 - 07:49 AM
I have a xr600, not a 650R and my bike has a removable screen at the bottom of the frame oil tank. That's where all the metal chips end up in my bike. If the 650R has that screen clean it. Flush the frame oil tank too.
There is an oil screen in the bottom of the crankcase too.
  • HawkGT
Posted April 04, 2006 - 11:13 AM
All:
[snip]...The inside of the paper filter looked clean....[snip]
The outside of the filter is where debris gets trapped. The oil gets forced from the outside of the filter to the inside and then on to the head, crank, and tranny.
  • SenorGG
Posted April 04, 2006 - 06:28 PM
Thanks guys:
Yes, I cleaned all the screens and checked the filter. My real question is whether there is any other way of oil getting from the crankcase to the engine without having to go through the paper filter.
  • Hot  29 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  186 replies
  • 22 replies
Honda XR650L 2017
  • 0 reviews
