wr426 problem with stalling
3 replies to this topic
  • lowry
Posted April 03, 2006 - 09:35 AM
So I just got my bike going after a long winter in hibernation. I changed the plug, put in fresh gas, cleaned the air filter and changed the oil. The bike starts and runs great but when I pull in the clutch and let off the gas after riding it the engine stalls. I've searched the forum as best I could and saw that one person had a similar problem and found it was the brake light switch causing it. Any idea what else could be causing this problem?
Thanks for your help.
  • jbrooks26
Posted April 03, 2006 - 09:46 AM
Idle set too low will cause this, but you probably already thought of that.
Josh
  • lowry
Posted April 03, 2006 - 10:10 AM
Josh
I had thought of that but I haven't tried adjusting it yet. For some reason I thought it would be a bigger deal than that because nothing had changed from last year. Who knows though, I may have bumped it when I drained the gas or took the tank off. Thanks.
  • jbrooks26
Posted April 03, 2006 - 10:48 AM
No problem, just to note though, I have to adjust mine almost every ride. My idle changes quite a bit with temp changes and it always idles higher when the engine is cold.
Josh
